Carlo 4561 Posted February 17, 2015 Posted February 17, 2015 BTW, I have TeamViewer on the Surface Pro 2 that is experiencing the person icon problem and can give remote teamviewer access to it if needed to play or check anything out. Don't know if that would be of help or not but I'm fine doing that. Just let me know, Carlo
7illusions 1249 Posted February 17, 2015 Author Posted February 17, 2015 Yet another build. .230 Serialization bugfix when in offline mode Replaced bottom appbar with ContextMenu in SeasonDetails view
Luke 42240 Posted February 18, 2015 Posted February 18, 2015 Any results here? We've added about a large number of beta testers over the past several days but only about half of you are active.
jasonmcroy 320 Posted February 18, 2015 Posted February 18, 2015 What log do I post when something goes awry? I can't find an app log, only the server log. Is that sufficient? I have so far only tested the syncing and all has gone fine except I have one file that won't play back in the app. It plays fine in all other clients and my vlc player. It's an avi file. -Jason
jasonmcroy 320 Posted February 18, 2015 Posted February 18, 2015 Important Now that we have a working build, can we get some testing on the following: - offline pin, instructions here: http://mediabrowser.tv/community/index.php?/topic/15548-beta-310/?p=178017 - offline watched state reported to server. instructions: 1. sign out of app 2. sign in via AnyTime SIgn in 3. Watch a video 4. Now sign back in online 5. Once the sync process completes, check the web interface, your watch state should now be reflected I am not seeing the option in my user tab/password tab to create a pin # as you describe in the linked post. Server version 3.0.5526.29593. I only get the option to put in a password, which by the way, whenever I try to set up a password it says "invalid user/password".
Vicpa 612 Posted February 18, 2015 Posted February 18, 2015 Hi, 230 The sync context menu for "multiple" items needs some additional wording to let you know you are syncing multiples. I think it will be confusing for new users. For example from Next up if you bring up anytime and select the defaults and sync you will get all episodes in the series. First time users will probably not expect that. Not sure but maybe the default should be unwatched or some additional verbiage. There is an inconsistency between offline indicators and display while actually offline. Online The above is correct. offline 14 is showing as there and isn't . Just curious in the above scenario if you are online. Will the app play the available tracks locally and the get the others online? The top command bar is not available via right click from the now playing screen. While online or off. Mostly minor stuff, all major functionality seems to be working well !! Will try to test some more. -vicpa 1
swhitmore 781 Posted February 18, 2015 Posted February 18, 2015 Hey, I'm getting a fatal crash when opening any library. Sequence: 112 Date/time: 2015-02-18T12:36:31.3391066+00:00 Level: ERROR Thread: 7 Logger: RtLogger ------------------------ Error getting response from http://192.168.1.10:8096/mediabrowser/Users/1ab79bc593c0f06fb57b9be621a8ede7/Items?Limit=5&SortBy=DateCreated&sortOrder=Descending&SeriesStatuses=&fields=&Filters=IsFolder&ImageTypes=&VideoTypes=&AirDays=&recursive=True&EnableImageTypes=&MediaTypes=&Genres=&Ids=&Studios=&ExcludeItemTypes=&IncludeItemTypes=BoxSet&Artists=&PersonTypes=&Years=&format=json ------------------------ System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (401) Unauthorized. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken) at System.Threading.Tasks.Task.Wait(TimeSpan timeout) at MediaBrowser.ApiInteraction.PortableHttpWebRequestFactory.<>c__DisplayClass5.<GetResponseAsync>b__4() at System.Threading.Tasks.Task`1.InnerInvoke() at System.Threading.Tasks.Task.Execute() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.ApiInteraction.Net.HttpWebRequestClient.<GetResponse>d__1.MoveNext() ---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (401) Unauthorized. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)<--- ------------------------ Session: {"PackageArchitecture":"Neutral","PackageFullName":"436337Illusions.com.MediaBrowser_3.1.0.230_neutral__77hd5e1v1hqs4","PackagePublisher":"CN=CA9FBA89-9B8C-4501-9177-37B89E41D3FF","PackagePublisherId":"77hd5e1v1hqs4","PackageResourceId":"","PackageVersion":"3.1.0.230","InstallationId":"b905ebeb-4ed3-4496-bee8-b3dab518b166"} Sequence: 115 Date/time: 2015-02-18T12:36:31.5369129+00:00 Level: FATAL Thread: 3 Logger: Application ------------------------ The application crashed: One or more errors occurred. ------------------------ MediaBrowser.Model.Net.HttpException: One or more errors occurred. ---> System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (401) Unauthorized. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken) at System.Threading.Tasks.Task.Wait(TimeSpan timeout) at MediaBrowser.ApiInteraction.PortableHttpWebRequestFactory.<>c__DisplayClass5.<GetResponseAsync>b__4() at System.Threading.Tasks.Task`1.InnerInvoke() at System.Threading.Tasks.Task.Execute() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.ApiInteraction.Net.HttpWebRequestClient.<GetResponse>d__1.MoveNext() --- End of inner exception stack trace --- at MediaBrowser.ApiInteraction.Net.HttpWebRequestClient.<GetResponse>d__1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.ApiInteraction.Net.HttpWebRequestClient.<SendAsync>d__f.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.ApiInteraction.ApiClient.<SendAsync>d__55.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.ApiInteraction.ApiClient.<GetItemsAsync>d__99.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Service.MoviesService.<GetTopBoxSets>d__4d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.ViewModels.MoviesHubViewModel.<OnNavigatedTo>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.AsyncMethodBuilderCore.<ThrowAsync>b__4(Object state) at System.Threading.WinRTSynchronizationContext.Invoker.InvokeCore() ------------------------ Session: {"PackageArchitecture":"Neutral","PackageFullName":"436337Illusions.com.MediaBrowser_3.1.0.230_neutral__77hd5e1v1hqs4","PackagePublisher":"CN=CA9FBA89-9B8C-4501-9177-37B89E41D3FF","PackagePublisherId":"77hd5e1v1hqs4","PackageResourceId":"","PackageVersion":"3.1.0.230","InstallationId":"b905ebeb-4ed3-4496-bee8-b3dab518b166"}
swhitmore 781 Posted February 18, 2015 Posted February 18, 2015 Also getting this error: Sequence: 32 Date/time: 2015-02-18T12:55:19.7086576+00:00 Level: ERROR Thread: 3 Logger: RtLogger ------------------------ Error sending web socket message ------------------------ System.NullReferenceException: Object reference not set to an instance of an object. at MediaBrowser.ApiInteraction.ApiClient.<SendWebSocketMessage>d__2f`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Service.SettingsService.<ServerSync>d__53.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.AsyncMethodBuilderCore.<ThrowAsync>b__4(Object state) at System.Threading.WinRTSynchronizationContext.Invoker.InvokeCore() ------------------------ Session: {"PackageArchitecture":"Neutral","PackageFullName":"436337Illusions.com.MediaBrowser_3.1.0.230_neutral__77hd5e1v1hqs4","PackagePublisher":"CN=CA9FBA89-9B8C-4501-9177-37B89E41D3FF","PackagePublisherId":"77hd5e1v1hqs4","PackageResourceId":"","PackageVersion":"3.1.0.230","InstallationId":"b905ebeb-4ed3-4496-bee8-b3dab518b166"} Sequence: 46 Date/time: 2015-02-18T12:55:20.1996622+00:00 Level: FATAL Thread: 3 Logger: Application ------------------------ The application crashed: Object reference not set to an instance of an object. ------------------------ System.NullReferenceException: Object reference not set to an instance of an object. at MediaBrowser.ApiInteraction.ApiClient.<SendWebSocketMessage>d__2f`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Service.SettingsService.<ServerSync>d__53.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.AsyncMethodBuilderCore.<ThrowAsync>b__4(Object state) at System.Threading.WinRTSynchronizationContext.Invoker.InvokeCore() ------------------------ Session: {"PackageArchitecture":"Neutral","PackageFullName":"436337Illusions.com.MediaBrowser_3.1.0.230_neutral__77hd5e1v1hqs4","PackagePublisher":"CN=CA9FBA89-9B8C-4501-9177-37B89E41D3FF","PackagePublisherId":"77hd5e1v1hqs4","PackageResourceId":"","PackageVersion":"3.1.0.230","InstallationId":"b905ebeb-4ed3-4496-bee8-b3dab518b166"}
7illusions 1249 Posted February 18, 2015 Author Posted February 18, 2015 New build is up, .231 Bugfixes.(Scott, can you give it another go, thanks.) German translation
mbnwa 49 Posted February 18, 2015 Posted February 18, 2015 (edited) Ok Sync completed and transferred however when I logout of the server and select AnyTime and login with my pin I see the heading AnyTime --> Click on TV --> Sleepy Hollow --> Episode --> Click Play --> Media Browser app brings me to desktop clicking on the Media Browser icon in the task bar brings be to the user login page for the server Episode is a m4v I am still seeing an issue with AnyTime - If I am logged into the server and select AnyTime and play back the episode I synced the playback works correctly however if I sign out of the server and hit skip - Connect to my server manually --> AnyTime Sign In --> Login --> Hit Play on item --> Media Browser changes focus to Desktop if I click on Media Browser icon when it comes back into Focus it takes me to the server login page. Edited February 18, 2015 by mbnwa
Luke 42240 Posted February 18, 2015 Posted February 18, 2015 ok yes, i do see that as well when playing offline video. so for me, that's the one open issue right now. offline audio working well, so is playing locally stored content while connected to the server.
7illusions 1249 Posted February 18, 2015 Author Posted February 18, 2015 Can you get me the crashlog for this? (charms-menu -> settings -> view logs) clear the logs first and then reproduce the crash. It should the be the log at the bottom of the list. Thanks
mbnwa 49 Posted February 18, 2015 Posted February 18, 2015 FATAL LOG: Sequence: 35Date/time: 2015-02-18T18:38:26.1075437+00:00Level: FATALThread: 3Logger: Application------------------------The application crashed: One or more errors occurred.------------------------MediaBrowser.Model.Net.HttpException: One or more errors occurred. ---> System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (401) Unauthorized. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken) at System.Threading.Tasks.Task.Wait(TimeSpan timeout) at MediaBrowser.ApiInteraction.PortableHttpWebRequestFactory.<>c__DisplayClass5.<GetResponseAsync>b__4() at System.Threading.Tasks.Task`1.InnerInvoke() at System.Threading.Tasks.Task.Execute()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.ApiInteraction.Net.HttpWebRequestClient.<GetResponse>d__1.MoveNext() --- End of inner exception stack trace --- at MediaBrowser.ApiInteraction.Net.HttpWebRequestClient.<GetResponse>d__1.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.ApiInteraction.Net.HttpWebRequestClient.<SendAsync>d__f.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.ApiInteraction.ApiClient.<SendAsync>d__55.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.ApiInteraction.ApiClient.<GetIntrosAsync>d__78.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Service.PlaybackService.<AddIntros>d__5.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Service.PlaybackService.<PlayItem>d__2.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.ViewModels.OfflineItemsViewModel.<PlaySelectedItem>d__4.MoveNext()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.AsyncMethodBuilderCore.<ThrowAsync>b__4(Object state) at System.Threading.WinRTSynchronizationContext.Invoker.InvokeCore()------------------------Session: {"PackageArchitecture":"Neutral","PackageFullName":"436337Illusions.com.MediaBrowser_3.1.0.231_neutral__77hd5e1v1hqs4","PackagePublisher":"CN=CA9FBA89-9B8C-4501-9177-37B89E41D3FF","PackagePublisherId":"77hd5e1v1hqs4","PackageResourceId":"","PackageVersion":"3.1.0.231","InstallationId":"40ed3e37-0d1b-4553-8c85-c29f5ee7adf7"}
mbnwa 49 Posted February 18, 2015 Posted February 18, 2015 ERROR LOG: Sequence: 32Date/time: 2015-02-18T18:38:26.1035405+00:00Level: ERRORThread: 5Logger: RtLogger------------------------Error getting response from http://192.168.50.10:8096/mediabrowser/Users/66f17f239d9172dd0aef9b4f6743c04c/Items/db72c06e7220591cb64beae17ccb3fa5/Intros?format=json------------------------System.AggregateException: One or more errors occurred. ---> System.Net.WebException: The remote server returned an error: (401) Unauthorized. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken) at System.Threading.Tasks.Task.Wait(TimeSpan timeout) at MediaBrowser.ApiInteraction.PortableHttpWebRequestFactory.<>c__DisplayClass5.<GetResponseAsync>b__4() at System.Threading.Tasks.Task`1.InnerInvoke() at System.Threading.Tasks.Task.Execute()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.ApiInteraction.Net.HttpWebRequestClient.<GetResponse>d__1.MoveNext()---> (Inner Exception #0) System.Net.WebException: The remote server returned an error: (401) Unauthorized. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)<--- ------------------------Session: {"PackageArchitecture":"Neutral","PackageFullName":"436337Illusions.com.MediaBrowser_3.1.0.231_neutral__77hd5e1v1hqs4","PackagePublisher":"CN=CA9FBA89-9B8C-4501-9177-37B89E41D3FF","PackagePublisherId":"77hd5e1v1hqs4","PackageResourceId":"","PackageVersion":"3.1.0.231","InstallationId":"40ed3e37-0d1b-4553-8c85-c29f5ee7adf7"}
Carlo 4561 Posted February 18, 2015 Posted February 18, 2015 7illusions, Any changes made so the menu under the person icon works? menu pops up but nothing works when you click on those menus. Without that functioning I can't do any testing on the 3 machines I have this installed on as they all do the same thing. Carlo
7illusions 1249 Posted February 18, 2015 Author Posted February 18, 2015 Not yet. Are the other context menus working? Try moviedetails view, click on the "..." Button and then the Play To or Browse To option since they will open a similar menu as the usericon. Thanks (just trying to figure out if it's only the usernenu or the base control itself)
Beardyname 199 Posted February 18, 2015 Posted February 18, 2015 (edited) Most of the stuff seems to work as it should now, have not experienced a crash yet on this version. sign in with pin works, syncing seems to work as it should as well. Will still test with the troublesome episode that refused the last time around. one bit of nitpicking if i may, on album view the button still says "sync" instead of anytime. *edit* also, i can sync playlists from the web-client to the app, but not from the app. *edit2* with a synced episode i tried to access with the off-line pin the app crashed instantly, does not happen if i playback the episode when I'm online and signed in. (still direct play from the disk) brb gonna attach logs Log - 20150218.log Log - FATAL - Application - 20150218 204638 - 105.log Edited February 18, 2015 by Beardyname
SilentAssassin 96 Posted February 18, 2015 Posted February 18, 2015 Not really had the time to test fully, just started the process of buying a house. I have noticed in the charms sync settings you get three options for quality, high, medium and low. However when you select the anytime (sync, which branding are we going with) option under the three dot button you then get four quality options, original, high, medium and low.
Luke 42240 Posted February 18, 2015 Posted February 18, 2015 AnyTime is what we're calling the offline mode, but they're still sync jobs. I think 7 just needs to get the option added to the other screen. And 7 - you'll want to grab the help text from the web client in relation to the quality option, so that users know if they force original it could result in the file not being playable on the device.
SilentAssassin 96 Posted February 18, 2015 Posted February 18, 2015 When you set something to sync you are still able set another sync job for the same item. Also the queued banner is larger than the poster width. When you set something to sync you should popup a message stating the process could take sometime, with maybe a button that takes you to the sync jobs screen.
SilentAssassin 96 Posted February 18, 2015 Posted February 18, 2015 Once an item is ready to transfer why do you need to exit out of the app and open again before it actually starts transferring? I've been testing using an mp4 which will play natively so I've been using the original quality setting meaning it's pretty much ready to transfer straight away. However needing to close the app and reopen seems unintuitive.
SilentAssassin 96 Posted February 18, 2015 Posted February 18, 2015 I didn't realise when you open the app when you are offline you would only see any media which you have synced, I assumed (makes a Ass out of U and me) you would be able to browse your whole library as normal, just that you could only play back items which had been synced. This got me when opening the app offline before I had synced anything and the anytime screen was blank, maybe could do with a message stating that nothing had been synced yet.
7illusions 1249 Posted February 18, 2015 Author Posted February 18, 2015 New build is up, .232 Bugfixes. Added "Original" as a option in default settings. Added describing text for Sync-qualities Offline playback crashfix Changed the events used for the context menus @@cayars @@Vicpa can you have another go at the menus?
Vicpa 612 Posted February 19, 2015 Posted February 19, 2015 Yea!!! The context and User icon menus are now working on my troublesome machine. Thank You 7. One thing so far Any entrance to a tv show brings you to the next up screen, like that. When you click on a season, the drill down to the shows doesn't work. See pic. When I click on the season icon nothing happens. I was thinking that as this release is also about view support. The New/Latest movies (maybe TV) do not honor the do not include in new content/do not group. If it is not a big deal, if this could be corrected before the production release that would be great. It is probably the most user facing thing. You open the app and new movies are right there and it is obvious if those settings are not honored. Good PR good first impression. Will test some more sync this pm and report. Icon menu thing was driving me batty, glad it is fixed. Hope is working for cayars, then can be marked as resolved. Thanks! -vicpa
