bennymac 47 Posted February 10, 2015 Posted February 10, 2015 (edited) you say you had the hopes, you're saying it's currently a let down? the api allows you to sync random lists of items so 7 could also do that. Nar not at all...I think the work being done here is fantastic and NOTHING here is a let down at all. Everything is evolving and it's awesome to see. That's why many of us hawk the forums scouring for hints of new stuff I just say 'hopes' as in it would be great, in that scenario. More of a quick entertainment on the go - type thing. Leaving for work in the morning, copy some music/playlists. Travel for work, copy movies and tv. Being able set the app in an offline mode and browse the content that's cached. As you say 7 could possibly add random sync lists, which would be very cool... I'll trying out build .214 now. I haven't been able to get a successful sync as yet. I'm heaps keen to try it. Edited February 10, 2015 by bennymac 1
bennymac 47 Posted February 10, 2015 Posted February 10, 2015 (edited) Fired up latest dev and build .214. Music synced up straight away, no problems. Thanks heaps. Edited February 10, 2015 by bennymac 1
Carlo 4561 Posted February 10, 2015 Posted February 10, 2015 Nar not at all...I think the work being done here is fantastic and NOTHING here is a let down at all. Everything is evolving and it's awesome to see. That's why many of us hawk the forums scouring for hints of new stuff I could not agree more!
Luke 42241 Posted February 10, 2015 Posted February 10, 2015 I thought I invited a whole bunch of people to test. It seems only half have actually participated.
AgileHumor 123 Posted February 10, 2015 Posted February 10, 2015 (edited) 214 PlayState: Pass EasyPin: Fail (could be that using local account, not MBConnect). Can't logon with easy pin (same as pasword) User Mucking: Deleting file from Sync Drive, Still Showed in Sync as "Synced" on device. Ran a sync different quality (medium) of same movie...deleted the orginal sync job with missing video...and by morning the new quality (medium) was synced and the original quality file not shown. Cancel Sync Job: Pass Other notes: * Significantly less crashing on startup. Still crashes during about 10% of sessions in interaction. * Playing Live TV has no back button to leave the currently playing media (I had to use keyboard backspace to return from playing video). EDIT: You must swipe up or down (right click) to bring up back button. * Syncing all of Game of Thrones was not ideal first test of TV (75% converted) syncing Edited February 10, 2015 by AgileHumor
7illusions 1249 Posted February 10, 2015 Author Posted February 10, 2015 @@AgileHumor Crashlogs or it never happened. 1
AgileHumor 123 Posted February 10, 2015 Posted February 10, 2015 @@AgileHumor Crashlogs or it never happened. Have you checked this post? i would post a lot of logs if it was everytime
bennymac 47 Posted February 10, 2015 Posted February 10, 2015 I get an app crash every time I use the "Offline Signin" button. Is this a known crash?
7illusions 1249 Posted February 10, 2015 Author Posted February 10, 2015 (edited) @@AgileHumor yes, that was 1 ApplicationCrash log there, and that issue is resolved. That's why I'm asking for the next. @@bennymac Can you get me the crashlog? (Charms-menu -> Settings -> View logs and scroll to the bottom until you find the "Application Crash" logs) Logs of interest has "FATAL" in the name Edited February 10, 2015 by 7illusions
Beardyname 199 Posted February 10, 2015 Posted February 10, 2015 (edited) I can not seek in synced media is that normal? (if played in vlc i can see how far i have watched) and it won't report playback status because of that either (aka no resume point). On the + side, if physically removed from the folder the app catches it really quick. *crap* removed the file before i could get an MediaInfo from it will try to sync it again. *edit2* the server and the app both lists the episode as "synced" and won't take the hint to convert and transfer the file again. Instead i have to remove the sync job and add the ep again, is this by design? Edited February 10, 2015 by Beardyname
Beardyname 199 Posted February 10, 2015 Posted February 10, 2015 (edited) Making a new post not to confuse, tried another episode set the quality to low and synced it over. It plays fine but does only track how far i have played and no progress is being reported. mediainfo : http://pastebin.com/5cE2X9i0 applog is attatched to the post. Log - 20150210.log Edited February 10, 2015 by Beardyname
bennymac 47 Posted February 10, 2015 Posted February 10, 2015 (edited) @@7illusions Here is the log. Thanks. Log - FATAL - Application - 20150210 213218 - 18.log Edited February 11, 2015 by bennymac
Luke 42241 Posted February 11, 2015 Posted February 11, 2015 I can not seek in synced media is that normal? (if played in vlc i can see how far i have watched) and it won't report playback status because of that either (aka no resume point). On the + side, if physically removed from the folder the app catches it really quick. *crap* removed the file before i could get an MediaInfo from it will try to sync it again. *edit2* the server and the app both lists the episode as "synced" and won't take the hint to convert and transfer the file again. Instead i have to remove the sync job and add the ep again, is this by design? the server will not resync in that situation, no. instead, once the app and server go through their sync processes, it will display on the server as removed from device.
swhitmore 781 Posted February 11, 2015 Posted February 11, 2015 the server will not resync in that situation, no. instead, once the app and server go through their sync processes, it will display on the server as removed from device. Has someone tested what happens if you uninstall the app?
swhitmore 781 Posted February 11, 2015 Posted February 11, 2015 Hi @@Luke. I'm getting this error when selecting the 'Sync' tab from the dashboard. Requested value 'InProgess' was not found. Server Log
Luke 42241 Posted February 11, 2015 Posted February 11, 2015 by the way in the latest server build, the Original quality option has been added. Note that this may often be the same result as High depending on device capabilities.
swhitmore 781 Posted February 11, 2015 Posted February 11, 2015 by the way in the latest server build, the Original quality option has been added. Note that this may often be the same result as High depending on device capabilities. Is it possible to detect that capability and merge the options to avoid confusion?
Luke 42241 Posted February 11, 2015 Posted February 11, 2015 no, it is not practical to run those tests ahead of time and not even possible when you take into consideration future items. Studies show the vast majority of users use applications at default settings, so that also reflects where most of our efforts go towards. So options like that can be tucked away under some advanced menu. to them, there won't be any confusion because they're just going to click OK without reading everything.
Vicpa 612 Posted February 11, 2015 Posted February 11, 2015 Hi, With the latest combo 214 and 5520.642. (or the one before) -stability is improved. one crash logs Log - 20150210.log Log - FATAL - Application - 20150210 232120 - 82.log -Sync to a alternative path isn't working for me, fine with default path. Maybe someone else can confirm. Let me know when you are ready for UI comments. Is anyone testing with a Win 8.1 Pro client with MC remote ? I still have one client that the menu choices under the user icon do not do anything. It is like the select event is not being triggered or captured. I know it seems crazy. I can get to the sync settings page from the charms menu, go figure. My latest guess is there is some weirdness going on between the mouse/keyboard, touch and MCE remote events. If anyone could confirm that would be great. Thanks
7illusions 1249 Posted February 11, 2015 Author Posted February 11, 2015 New build up, .215 Bugfixes Moved Offline view to Main Menu views. Nuget updates 2
Vicpa 612 Posted February 12, 2015 Posted February 12, 2015 Hi, 215 crashes when you attempt to create a sync job. Logs Log - 20150212.log Log - FATAL - Application - 20150212 165832 - 81.log Thanks
AgileHumor 123 Posted February 12, 2015 Posted February 12, 2015 App hangs on start when sync drive/path (if on removable drive) is not available. Not a major deal but FYI it may need a error check for future, future builds.
Beardyname 199 Posted February 12, 2015 Posted February 12, 2015 Hi, 215 crashes when you attempt to create a sync job. Logs Log - 20150212.log Log - FATAL - Application - 20150212 165832 - 81.log Thanks same for me. Do you need my logs as well?
7illusions 1249 Posted February 12, 2015 Author Posted February 12, 2015 New build is up, .216 Fixes the sync-job crash. I've also done a little test which I want your feedback on before progressing with the design and implementation. If you make sure to use the touch UI (Charms-menu -> Settings -> Unmark "Use Mouse & Keyboard layout" if on) Go into a movie details view. What I've done is to remove the bottom appbar and Replaced the playTo button with a "more" button instead which shows a contextmenu similar to how the Webclient does. The design is REALLY temporary, I wanted your feedback on InteractionDesign prior to Graphics work.. If you like it I will add it to more places and hopfully get rid of the bottom appbar totally 1
bennymac 47 Posted February 13, 2015 Posted February 13, 2015 @@7illusions I like much more than having to swipe down to access the appbar. Nice work!
