ab123ga 18 Posted December 12, 2014 Posted December 12, 2014 Question: I'm in the process of re-encoding all of my movies into a different format (and extension) and put them in the same folder where the original was.. I'm planning on removing the original so I only have the new one. Is there a way to prevent MB from seeing the new format/extension as a separate movie and adding it's own meta data etc? Since I use both MB and Plex, I have to do the following dance to minimize manual clean up. 1) Shutdown MB 2) Add new movie 3) Do a manual update in Plex (Plex then shows 2 copies of the movie...puts a 2 in the corner) 4) Remove the old movie 5) Do another manual update in Plex (now has 1 movies) 6) Start MB. MB does a scan and the new movie holds the metadata posters, etc of the original Prior to doing the above, I would just add the new and remove the old before MB had a chance to do a refresh. The problem with that when Plex does an update, it sees this as a newly added movie and I want to maintain my "recently added" in both MB and Plex. No big deal if there's no way to do this. The above works fine.
Solution AdrianW 1058 Posted December 12, 2014 Solution Posted December 12, 2014 Why not just disable the "Scan media library" schedule task whilst you do all this re-encoding. (Advanced > Schedule Tasks). And then re-enable it after you've finished. In the mean time you can manually run scans when you want to (there's a button at the bottom of the "Library" section). 1
ab123ga 18 Posted December 12, 2014 Author Posted December 12, 2014 Yes... I suppose I could do that but I would also have to shut down the real time monitoring as well. That's probably a better option than shutting down the server each time I get a new batch. Thanks much...
