bdevild 1 Posted December 12, 2014 Posted December 12, 2014 (edited) I just upgraded to 3.0.5545.6 server and 3.0.238 MBC from 2 and now the FF, RW, skip, and numbers buttons do not work for my media center remote on the 360. This occurs while playing WMV format movies. I read the usage guide and tried all options with no luck. The remote works fine on my native windows machine w/ the remote usb adapter. Is this a known issue? Edited December 12, 2014 by bdevild
ebr 16334 Posted December 12, 2014 Posted December 12, 2014 The number buttons are known with the custom interface. If you turn off the custom player interface, do all those functions work?
bdevild 1 Posted December 13, 2014 Author Posted December 13, 2014 I tried that with no luck. The time index (what time in the movie) only shows the current second playing on the far right - e.g. at 10 seconds it shows a full bar and 10 seconds all the way to the right and not 1:38:00 (whatever length of movie). FF/RW/Skip do not work still. I tried this with Chocolate and with Classic themes and with turning off every option in Playback as well. Nothing seemed to work. Anything in logs useful to you? Or other options to try?
Solution ebr 16334 Posted December 13, 2014 Solution Posted December 13, 2014 It sounds like maybe you haven't setup permissions properly such that your extender can access the media directly so it is streaming it instead.
bdevild 1 Posted December 17, 2014 Author Posted December 17, 2014 Thanks! That was the issue. For clarity of issue and resolution... Issue 1) After installing MB3 I mapped the network shares from my NAS by clicking through the GUI selector in MB3. -e.g. Network > NAS > Movies for \\NAS\Movies 2) All features works fine on PC 3) Libraries appear but Xbox is streaming thus no FF/RW Fix 1) I added these as Media Libraries in Media Center Settings menu manually with authentication - e.g. type in \\NAS\Movies and user=[username] and pw=[pass] of NAS user 2) FF/RW works correctly 1
MrWebsmith 598 Posted December 17, 2014 Posted December 17, 2014 thank you for posting your solution..it will likely help future extender/360 users
