Issue Launching MBT with Relaunch
I used Relaunch to add MBT to the WMC Extras Library. I have never had any issues launching programs this way before but for some reason MBT will not launch the first time, e.g. I select MBT from the Extras Library, WMC minimizes but MBT does not launch. I then select the menu button to relaunch WMC, select MBT again from the Extras Library, and this time MBT launches. This happens whenever I restart my PC or haven't launched MBT for a while while loged on.
A moderator mentions Relaunch in this topic
I'm using C:\Users\_______\AppData\Roaming\MediaBrowser-Theater\System\MediaBrowser.UI.exe for the path
What is unique about the MBT exe file that would stop it from launching the first time? Any ideas what might be causing this?
I was thinking of trying MBC but I don't want it in the WMC main menu. Can MBC be launched from the Extras Library? Can both MBT and MBC be installed together on the same PC?
