Allow AAC audio stream-copy (or 2.0 fallback instead of 5.1 E-AC3) during Live TV HLS timeshift on Android TV
IkeTaylor11
When Direct stream live TV is turned OFF on Nvidia SHIELD (AndroidTv 2.5.05g / 2.5.09g) to enable pause/rewind, Emby forces a 2.0 AAC -> 5.1 E-AC3 audio transcode even when the incoming MPEG-TS stream has valid stereo AAC headers:
Plaintext
Input #0, mpegts:
  Stream #0:0[0x100]: Video: h264 (High), yuv420p(progressive), 1280x720, 29.97 fps
  Stream #0:1[0x101](und): Audio: aac (LC), 48000 Hz, stereo, fltp, 127 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (aac (native) -> eac3 (native))
Output #0, segment:
  Stream #0:1: Audio: eac3, 48000 Hz, 5.1(side), fltp, 192 kb/s (default)
Since ExoPlayer on Android TV natively supports AAC inside MPEG-TS HLS segments (AudioCodec=eac3,ac3,aac...), is there a way to allow aac audio stream-copy during Live TV timeshifting—or preserve the original 2.0 channel layout instead of upmixing stereo to 5.1 E-AC3 for AVR users?
HI, why would this need to be specific to live tv ?
IkeTaylor11
Its the only time the issue comes up. I don't experience it with tv shows or movies.
