Emby will not play a small number of shows on Roku, but will play on other devices.
Hi, I have a weird thing happening.
I have 3 shows that have failed to play on Roku.  They start, the spinning wheel appears, after a bit moves to 13% and then stays stuck there until you cancel out.
I replaced one of the shows with different files at a different resolution and it did exactly the same thing.
All of the shows play fine using a windows machine, both inside the Emby app and from the browser.
It seems to be completely show specific.  Once it gets unhappy with a show, it seems to stay unhappy with all future episodes of that show.  If I watch one on Windows then try to watch the next episode on Roku, same problem.
When I compared the logs from a show that played fine versus one that was stuck, the only thing I saw was that the response 206 line took 200ms and happened after the "http/1.1 Response completed after client disconnected to host2." line.  This was when the Roku failed to play.
So I'm not sure if there's something in the Roku app that doesn't like the sequence of events happening or if this is just a random result, not the problem.
I have tried repeatedly on different days to play the files, and they always fail on the Roku and always succeed on Windows.
The server itself (Synology) has been rebooted a couple times, and there are no problems recorded in the log on the Synology, the reboots changed nothing.  I have also upgraded the Emby server during the time frame this has been happening.  Currently on 4.10.2.0.
There is no transcoding happening, just a straight feed of the file to the Roku.
There are no mods or add-ons on the Emby server.
The Rokus are stand alone devices (Roku Premiere+).
Emby Log Failed Play.txt
Quote
2026-11-25 14:04:30.267 Info VideoService-0HNQAOK111QDI:00000001: http/1.1 GET http://192.168.5.27:8096/emby/videos/29762/original.mkv?DeviceId=deb09eeb-d4c4-5e2b-92ec-91aecb83580e&MediaSourceId=mediasource_29762&PlaySessionId=f9e70f702f854d5c8063bce85ae85861&api_key=x_secret4_x. Source Ip: host2, Accept=*/*, Host=192.168.5.27:8096, User-Agent=Roku/DVP-16.0 (16.0.4.853-29), Range=Bytes=3799514396-
It looks like something is at the end of the file. The Roku has to now download the entire thing up to that point to obtain it. Then it can restart.
The file isn't optimized for streaming. This is a file made for downloading. Once you remux the header will be rebuilt with all that information at the start of the file instead of any of it at the end. Run this file through MKVToolNix and simply "start remux" and let it create a new MKV container it will fix the issue more than likely. MKVToolNix will create a streaming friendly MKV.
When people encode the file sometimes they mistakenly put things needed for streaming at the end of the file. This is fine for some players. They can work around missing parts. But the Roku is not one of those players. It needs that so it will wait and download then fill up the buffer and realize it cannot play it. Because it is direct playing. It looks like you are exit playback rather than wait on that spinner. It should try to fallback to transcoding and eventually start to play. But it will just take an eternity. How long that eternity is I cannot tell you. It should eventually either play or wind up on the red toast message "no compatible streams available". But it also could just hang indefinitely.
Once you fix the file with MKVToolNix it should play immediately without any hitches. Let us know if remux does not fix it.
Edited by speechles
