Camera Upload makes Problems
Hello,
I’m having an issue with Camera Upload in Emby for Android. On the same Android device and Emby server, Camera Upload does not work with app version 3.5.72, but it works after installing version 3.5.36. I did not change the server or storage configuration between these tests.
Details
Android device: [manufacturer and model]
Android version: [version]
Emby for Android 3.5.72: Camera Upload fails
Emby for Android 3.5.36: Camera Upload works
Emby Server: 4.10.2.0, running on Linux
Camera Upload destination: [exact path shown in the Emby app/server settings]
The Android logs from the failing version showed this JavaScript error in settings/cameraupload.js after authorizeCameraRollAccess:
Cannot read properties of undefined (reading 'then')
The Android media permissions were granted. The upload folder is on a ZFS-backed mount; the Emby user has read and write access to it.
Could this be a regression in version 3.5.72? Please let me know if you need additional diagnostic logs or steps to reproduce it.
Thank you.
Hi, yes this is resolved in the next update to the Emby Android app. Thanks.
