[Beta] OPPO UDP-203/205 plugins: play your Emby library on the OPPO (ISO, BDMV, MKV, Dolby Vision)
Hi everyone,
I'd like to share two plugins I wrote to use Emby as the library front end for an OPPO UDP-203 / UDP-205 (or a compatible clone). The OPPO plays the original file, so you keep the disc menus, Dolby Vision and lossless audio, and Emby keeps track of progress. Testers and feedback are welcome. Once they have had some testing, I'd like to submit them to the plugin catalog.
Emby.Oppo
  • Adds the OPPO to Emby's "Play on…" menu for ISOs, BDMV folders, MKV and other files. Resume and watched status work.
  • The player reads the file from your NFS or SMB share. If the player runs the oppo-dv-mkv mod, the plugin can send it over DLNA instead (optional).
  • Audio and subtitle track selection, and multi-disc titles.
  • "Movie without menus" for Blu-ray discs starts the main movie directly. With the mod, Dolby Vision, chapters and resume are kept.
  • Dolby Atmos and DTS:X detection. ffprobe doesn't report them, so the plugin reads the audio itself and writes the result into Emby's track info.
  • A web remote, also available as an Android app:
    library browsing with filters (4K, Dolby Vision, HDR, Atmos, DTS:X…) and title pages;
    live player output info (resolution, HDR, audio format);
    transport keys and chapter thumbnails.
  • English and French interface.
Emby.IsoBluray
  • Reads inside Blu-ray ISOs and BDMV folders (UDF 2.50, MPLS playlists). Emby then shows the real audio and subtitle tracks, the correct runtime and the format (UHD, HDR, 3D).
Requirements
  • Emby Server 4.9 or 4.10. I develop on 4.10 in Docker on a Synology. Windows paths are supported, and feedback from Windows users is welcome.
  • An OPPO UDP-203/205 with IP control enabled and a fixed IP address.
  • Either an NFS/SMB share the player can reach, or the oppo-dv-mkv mod for DLNA playback.
About the mod: DLNA playback relies on oppo-dv-mkv by fandangos, a third-party modification of the player's firmware. It is optional: without it, the plugin uses your share. I am not involved in the mod, and installing it is at your own risk.
Install:
  • Copy both DLLs (attached) into the plugins folder of your Emby server.
  • Restart Emby.
  • Run the scheduled task "Blu-ray: tracks and runtimes" once.
The full guide, screenshots and changelog are on GitHub: https://github.com/run51/emby-oppo-remote
The plugins were written from scratch on the OPPO's public IP control protocol and Emby's plugin API. Open source (MIT). Not affiliated with OPPO.
OPPO-Home.apk Emby.IsoBluray.dll Emby.Oppo.dll OPPO.apk
Thanks for sharing.
  • Agree 1
