gregsnell 1 Posted 13 hours ago Posted 13 hours ago (edited) Currently when editing the metadata for an item that has multiple versions, only the main versions metadata is actually edited (certainly as far as tags are concerned). This means that when I add a tag to say "Apocalypse Now" which is meant to restrict access based on tags any different versions remain accessible by the people it's not meant to be accessible to. The workaround is to ungroup the versions, edit each version's metadata separately, and then regroup them. Ideally, where there are grouped versions, a notice should appear in the editor with an option presented to bulk edit all versions. If this option is unchecked, users should be able to use "<<" or ">>" buttons to cycle through to which specific version they wish to edit using the same text that appears in the "Versions" box to identify between versions. I appreciate this is similar to "bulk edit" and "save and go to next" suggestions, however implementations of those suggestions could easily overlook this particular necessity. Edited 13 hours ago by gregsnell Grammar
