I recently did some upgrades to take advantage of streaming 4K Remux Blu Rays. I started out having problems with it buffering/stuttering no matter what I tried. Just to test, I decided to move 1 of the movies from my Synology Nas DS418play directly onto my hard drive that runs my Emby server. It played perfectly when I did that. So the issue must be with bandwidth from my NAS. I have the NAS and my computer both hooked up to a gigabit switch. Is it really possible that my older NAS can't output enough bandwidth to stream 4K remux files? That seems pretty basic. I found 1 topic in the forum about switching the drives to NTFS, but kind of got lost. Any advice?
Is this the correct file? I tried testing several things including decreasing the max bandwidth which resulted in the video being transcoded. Transcoded video did work perfectly. But every time I tried a setting that resulted in direct play it also resulted in freezing. Firestick is a 4k max second gen and it is hard wired to the network as well.
embyserver-63930902400.txt
Hi.  Try hooking it up wirelessly.
