Leafstrider 1 Posted 17 hours ago Posted 17 hours ago im in snohomish county, zip 98201, cable provider Xfinity/comcast, has been adding and moving alot of movie channels i watch and alot of others up to 40XX to 44XX can we get the numbers and listings updated? it would sure make it easier to watch and record. if you would like just the ones i watch, i can add the numbers here also. Thanks
sa2000 886 Posted 1 hour ago Posted 1 hour ago (edited) @LeafstriderCould you confirm that the Xfinity Cable Lineup you are using is one with Lineup ID USA-WA46459-X You can view the Lineup ID in Server Settings Dashboard: Live TV settings Setup tab under Guide Data Sources Assuming this is the guide data source you are using which is the cable Xfinity lineup for zip 98201, I am attaching list of the channel numbers and call signs in this guide lineup. I have no visibility of what channel numbers are set by Xfinity so I need you to go through this list and tell me what is wrong and what needs to be corrected or added - and I will then refer it to Gracenote. Thanks Attaching Microsoft Excel and text views of the current lineup channels for you to look at Channel Numbers for USA-WA46459-X.txtChannel Numbers for USA-WA46459-X.xlsx Edited 1 hour ago by sa2000
