KondiCool 3 Posted Sunday at 11:47 AM Posted Sunday at 11:47 AM Hi, Is there any way on the Emby server side to disable detection of the client's connection speed, so that transcoding (video or audio) doesn't get triggered by an automatically misdetected maximum connection speed?
Normanos 19 Posted Sunday at 05:01 PM Posted Sunday at 05:01 PM @ebrNoticed that it don't wish to work. Enabled 200Mb/s in user override, have users with "Auto" in Max. playback, but still transcoding often. Emby says that transcoding because of clients settings (something like that). Have no one using Emby at the moment. Internet speed also not an issue. They have 1Gb/s broadband, I have 8 Gb/s. It would be great to just disable clients connection test.
js28194 79 Posted Sunday at 08:18 PM Posted Sunday at 08:18 PM 3 hours ago, Normanos said: @ebrNoticed that it don't wish to work. Enabled 200Mb/s in user override, have users with "Auto" in Max. playback, but still transcoding often. Emby says that transcoding because of clients settings (something like that). Have no one using Emby at the moment. Internet speed also not an issue. They have 1Gb/s broadband, I have 8 Gb/s. It would be great to just disable clients connection test. So to be clear... your 8Gb connection is a standard 1GB, which is pretty common Fiber. Their 1Gb internet connection translates to about a 250MB connection which sounds like either a standard Cable or possible Fiber. Since I'm suspecting Cable which is shared throughout and heavily dependent upon usage in the entire neighborhood also, they may not be fully reaching that hence the need for transcoding. I'm just speculating.
Luke 43682 Posted Sunday at 08:49 PM Posted Sunday at 08:49 PM 3 hours ago, Normanos said: @ebrNoticed that it don't wish to work. Enabled 200Mb/s in user override, have users with "Auto" in Max. playback That does disable the client connection test.
yocker 2084 Posted Sunday at 09:10 PM Posted Sunday at 09:10 PM 4 hours ago, Normanos said: @ebrNoticed that it don't wish to work. Enabled 200Mb/s in user override, have users with "Auto" in Max. playback, but still transcoding often. Emby says that transcoding because of clients settings (something like that). Have no one using Emby at the moment. If it says "Reducing bitrate due to quality settings" then the user most likely set the quality setting them self. You can disable transcoding completely for a user if that is what you want.
Normanos 19 Posted Monday at 09:08 AM Posted Monday at 09:08 AM 12 hours ago, js28194 said: So to be clear... your 8Gb connection is a standard 1GB, which is pretty common Fiber. Their 1Gb internet connection translates to about a 250MB connection which sounds like either a standard Cable or possible Fiber. Since I'm suspecting Cable which is shared throughout and heavily dependent upon usage in the entire neighborhood also, they may not be fully reaching that hence the need for transcoding. I'm just speculating. All in UK and fibre symmetric broadband. Also, in different providers and locations. 11 hours ago, yocker said: If it says "Reducing bitrate due to quality settings" then the user most likely set the quality setting them self. You can disable transcoding completely for a user if that is what you want. They have it on Auto. 12 hours ago, Luke said: That does disable the client connection test. Ok, it's not a really problem for me, if transcoding, just something feels odd. @Luke Added log files just for information. Might be that client apps forcing lower quality. embyserver.txt ffmpeg-transcode-892db994-a19a-421d-9551-123ed269edf7_1.txt
ebr 17091 Posted Monday at 02:03 PM Posted Monday at 02:03 PM Hi. That playback requested 1.6Mb/s. I notice it is on the LG app. That store is very slow to update so perhaps that is related. App: Emby for LG 1.0.51
Luke 43682 Posted Monday at 03:01 PM Posted Monday at 03:01 PM 5 hours ago, Normanos said: All in UK and fibre symmetric broadband. Also, in different providers and locations. They have it on Auto. Ok, it's not a really problem for me, if transcoding, just something feels odd. @Luke Added log files just for information. Might be that client apps forcing lower quality. embyserver.txt 14.6 MB · 1 download ffmpeg-transcode-892db994-a19a-421d-9551-123ed269edf7_1.txt 291.94 kB · 2 downloads How is the quality setting in the app configured?
Normanos 19 Posted 2 hours ago Posted 2 hours ago @LukeThey are on auto in app. @ebrOf course, no one using these days Emby, but I'm more and more wish to blame LG app. Are You interested in more transcoding log files? Don't have any at the moment. Transcoding is not a massive problem for me as have just few users, but wish to help improve Emby, if I can.
