Shield 2019 Pro with BT headphones, no audio from Emby
Hi,
I am using Emby for Android TV in my Shield 2019 Pro. During late night watching I need to use BT headphones. However, the audio does not work for TV series and movies if I do that. That is, the headphones are silent. If I use my TV to play the audio, it works OK. FLAC files (my music files) work OK for headphones also. Additionally, for all other apps (youtube, etc.) the audio works OK in my headphones. I have tried to change Emby for Android TV settings (pass through settings especially) but that is not making any difference.
I guess this is an issue with some setting that I need to change. What setting that might be? Or is this something else?
Best regards and thank you for the help,
PT
Hi.  Are you pairing the headphones with the TV or Shield?  Be sure to pair with the Shield.
