SSL Certificate of authority issue?
Hi,
I have installed a new SSL cert on my server and the emby app on android shows a cert error and asks if I want to continue.
Are the cedrtificate of authority up to date in the Emby app for Android/Fire TV, Samsung and LG TVs??
I have checked Web browsers on Linux/Mac/Windows/Android & the Silk browser on Fire TV which have no problem and show the cert is vaild.
Cert info:
Issued by:
Common Name (CN) GlobalSign GCC R46 AlphaSSL CA 2025
Issued On    Saturday, 14 November 2026 at 14:29:12
Expires On    Tuesday, 1 June 2027 at 15:29:12indows
Thank you
Edited by dannyjc
add tags
That issuer is an intermediate cert and you should include it in your keystore (Emby pfx) along with the server cert.
Not all trust stores include intermediate certs. Some browsers use their own trust store while others use the system's. Comparing browsers and apps can be inconsistent on different platforms.
Edited by Q-Droid
I forgot to add LG and Samsung TV's refuse to connect using SSL
Samsun don't trust let's encrypt.
Just a fyi if that's being used.
Right now I'm guessing.
But details are lacking from your issue.
So still guessing.
Hi,
I have been buying the cert via ssl2buy.com from 2019 and just keep reissuing a new cert when required. I have an AlphaSSL Wildcard Certificate.
Emby has been working fine on Samsung and LG TVs over https for the last 7 years until the new cert.
with apache its simple just put the new certificate.crt in place and restart.
with emby I use the provided certificate.p7b and do the following
The p7b file contains the complete certificate chain in one file
openssl pkcs7 -print_certs -in certificatename.p7b -out certificatename.cer
openssl pkcs12 -export -in certificatename.cer -inkey privateKey.key -out certificatename.pfx
To check:
openssl pkcs12 -info -in certificatename.pfx
Enter Import Password:
MAC: sha256, Iteration 2048
MAC length: 32, salt length: 16
PKCS7 Encrypted data: PBES2, PBKDF2, AES-256-CBC, Iteration 2048, PRF hmacWithSHA256
Certificate bag
Bag Attributes
   localKeyID: 66 90 80 0D 54 F5 10 EE B5 AA 52 3F 39 CB 24 CD EF B2 66 FE
subject=CN=*.domain.name
issuer=C=BE, O=GlobalSign nv-sa, CN=GlobalSign GCC R46 AlphaSSL CA 2025
If that's the only cert listed in the output along with the private key then the p7b didn't contain the full chain or it wasn't imported for some reason.
i have the following:
Certificate bag
Bag Attributes
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
Certificate bag
Bag Attributes: <No Attributes>
subject=C=BE, O=GlobalSign nv-sa, CN=GlobalSign GCC R46 AlphaSSL CA 2025
issuer=C=BE, O=GlobalSign nv-sa, CN=GlobalSign Root R46
Certificate bag
subject=C=BE, O=GlobalSign nv-sa, CN=GlobalSign Root R46
PKCS7 Data
Shrouded Keybag: PBES2, PBKDF2, AES-256-CBC, Iteration 2048, PRF hmacWithSHA256
dannyc@m15x:~/Downloads/CEAP261114297911/PKCS7$
That looks good.
What do you get from this? The same chain should be in the reply.
openssl s_client -connect <emby host or ip>:<emby tls port>
they are all there
Connecting to 192.168.1.253
CONNECTED(00000003)
depth=2 C=BE, O=GlobalSign nv-sa, CN=GlobalSign Root R46
verify return:1
depth=1 C=BE, O=GlobalSign nv-sa, CN=GlobalSign GCC R46 AlphaSSL CA 2025
verify return:1
depth=0 CN=*.domain.name
verify return:1
Certificate chain
 0 s:CN=*.domain.name
   i:C=BE, O=GlobalSign nv-sa, CN=GlobalSign GCC R46 AlphaSSL CA 2025
   a:PKEY: RSA, 2048 (bit); sigalg: sha256WithRSAEncryption
   v:NotBefore: Nov 14 14:29:12 2026 GMT; NotAfter: Jun  1 14:29:12 2027 GMT
 1 s:C=BE, O=GlobalSign nv-sa, CN=GlobalSign GCC R46 AlphaSSL CA 2025
   i:C=BE, O=GlobalSign nv-sa, CN=GlobalSign Root R46
   v:NotBefore: Sep 17 02:55:30 2025 GMT; NotAfter: Jun 23 00:00:00 2029 GMT
Server certificate
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: rsa_pss_rsae_sha256
Negotiated TLS1.3 group: X25519MLKEM768
SSL handshake has read 4637 bytes and written 1655 bytes
Verification: OK
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Protocol: TLSv1.3
Server public key is 2048 bit
This TLS version forbids renegotiation.
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
ECH: NOT CONFIGURED: -103
Post-Handshake New Session Ticket arrived:
Edited by dannyjc
I was wondering if the emby app has its own key store which is out dated for the root certs?
Edited by dannyjc
I don't know. I would've thought they rely on the system though that could become a problem on older devices that don't get updates. Old TV's are notorious for not working with newer Root CAs.
Do you remember what chain issued your previous cert?
It looks like GlobalSign made some changes recently.
Quote
Migration from Multi-Purpose Roots: GlobalSign transitioned public TLS issuance away from older multi-purpose roots (like R3, R5, and R6) to TLS-dedicated roots in July and September 2026 as browser policies tightened (including Chrome's SCTNotAfter constraint on multi-purpose roots).
If you can find the chain for your previous cert then I would ask GlobalSign to reissue your new cert but using the Root R46 that is cross-signed with your previous Root, because that was working.
Edited by Q-Droid
One more thing, @Luke is Emby presenting all of the chain certs present in the PFX during the TLS handshake or is the chain cut off at 2 (depth=1)?
its been GlobalSign for years.
They have made changes for the new cert ie R46 is a change.
I think the Root R46 is not being recognised by Emby.
If Emby was using the system Root CA on Android or Fire Stick the cert should be recognised as the Silk browser has no problem (unless silk has its own keystore)
There are multiple things to consider that could be affecting you.
1. GlobalSign transition to R46. This is a newer root that older devices might not have and might never get.
2. We don't know for sure which trust store the Emby app is using and whether it's consistent. It could be its own on some platforms and the system on others. Using its own would be a better option since the app gets updated.
3. I suspect that the Emby server might be cutting off the chain at depth=1 during the handshake but @Luke would have to confirm that. Your output above would suggest this is happening.
4. GlobalSign has crossed-signed versions of the R46 root for this very scenario. They are signed with R1, R3 and R6 so that older devices can still validate new certs.
If you could get a cert issued by the version of R46 cross-signed with R6 it might be a step in the right direction. But only if R6 is in the client trust stores. R1 (2028) and R3 (2029) are expiring.
Then we need to know if Emby server does indeed present all of the certs in the PFX because the full chain becomes four certs with at least three of them needed during the handshake. Once we know what Emby is doing there are options to use your current cert and update the Emby PFX to contain the cross-signed R46 instead of the one you have now.
And if Emby does cut at depth=1 then you're looking at either changing CA to one with a shorter chain more likely to work with older clients or spinning up a reverse proxy where you'd have more control of the TLS configuration.
Edited by Q-Droid
@dannyjc
After doing a little reading on .Net's handling of TLS handshakes and keystores I think this is worth a shot.
Get these two certs below:
https://support.globalsign.com/ca-certificates/globalsign-cross-certificates
GlobalSign Cross Certificate R6-R46
https://support.globalsign.com/ca-certificates/globalsign-root-certificates
R6 GlobalSign Root Certificate
Then remove the Root R46 from the certificatename.cer you have now and add the two above to that stack. Recreate your PFX then check to see what openssl -info and openssl s_client print out after you restart Emby. I think it should then present the chain down to R46 (depth=2) and hopefully the Root R6 is old enough to be on the TVs and Android devices.
Quote
Not intentionally. It could be happening within aspnetcore, but I haven’t heard that reported before.
  • Thanks 1
Thanks. I think (and from what I've read) that by default during the handshake it excludes the self-signed (root) certificate from the chain assembly and transmission. So fairly normal behavior.
  • Thanks 1
dannyjc
Hi,
I change te certs, but still doesnt work on Samsung and LG TVs.
I will get them to dust off the firesticks to use for emby.
Thank you for your help
verify return:1
verify return:1
verify return:1
Certificate chain
Server certificate
Edited by dannyjc
8 minutes ago, dannyjc said:
Hi,
verify return:1
verify return:1
verify return:1
Certificate chain
Server certificate
Hi, what did you try changing to?
Q-Droid
What is the output from openssl pkcs12 -info -in certificatename.pfx?
dannyjc
Certificate bag
Bag Attributes
Certificate bag
issuer=OU=GlobalSign Root CA - R6, O=GlobalSign, CN=GlobalSign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Certificate bag
subject=OU=GlobalSign Root CA - R6, O=GlobalSign, CN=GlobalSign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PKCS7 Data
Bag Attributes
Key Attributes: <No Attributes>
Q-Droid
Is the Alpha missing from the keystore? I don't see it in the list.
