Angelblue05 4132 Posted December 7, 2014 Posted December 7, 2014 It's been a little bit since I've posted on MediaBrowser/XBMB3C forums. Version: MediaBrowser 0.9.721, MBS 3.0.5445.6 Problem: I'm unable to pause the content playing on XBMC via the web client. This used to work (could not say when it stopped working). Unfortunately, I'm not able to capture the log that would display what's happening when I try to use pause. Everything else still works (seeking, stop).
Unreal.2K7 0 Posted January 18, 2015 Posted January 18, 2015 Bring up this thread because of the same problem i'm facing. I have a raspberry Pi with OpenElec and XBMB3C addon. I'm able to play media on it remotely via any device. Through the web client's remote control feature i can seek and stop fine. Pausing doesn't work though. I'm trying to get a logfile for what is happening when i do this, but if i turn on DLNA debug logging i don't seem to be able to cause anything to be written in the log file. I will try again tomorrow.
Luke 42234 Posted January 19, 2015 Posted January 19, 2015 you're playing to the add-on or to xbmc as a generic upnp device?
Unreal.2K7 0 Posted January 19, 2015 Posted January 19, 2015 (edited) To the addon. Also, if i try to play to xbmc directly, in the remote control panel i only get to change the volume and the muting button. The playback controls are grayed out in that scenario. Thank you for your continued help! =) Edited January 19, 2015 by Unreal.2K7
