Emby not using NFOs
jackkeller
I am using TinyMM to create the NFO so I can get the IMDB listing for cast on episodes. I have tried re-scanning my show as well renaming the folder to force a new import but I cannot get Emby to grab the vast info.
Under Library, I have NFO selected for Metadata Readers.  I have Metadata Savers set to blank (I tried it both ways, though.)
I've attached one of the NFO in case that helps.
The naming format is:
The 100 - S01E04 - Murphy's Law.mp4
The 100 - S01E04 - Murphy's Law.nfo
Hi, what exactly makes you think the nfo isn't being used ?
jackkeller
I just rea;ized it's not picking up any of the files outside the video file. I have subtitles next to it, and they are not showing either.
jackkeller
The cast listed in the NFO is not showing up when I click on the episode. But it looks like there is something else wrong since it's not seeing the subtitles.
Subtitles have nothing to do with the nfo. I would refresh the metadata on the episode and then please attach the emby server log.
Thanks.
