lessyen 1 Posted November 3 Posted November 3 Hello, I have Synology DS218 (DSM 7.4.1-90080 Update 1), after the latest Emby update (v4.10.2.0), I’m having a problem with newly added movies metadata (pictures) — specifically with the previews, actors, etc. (as if the movie metadata isn’t linking properly to the libraries)—even though all the information on TMDB is correct.. Any solution??
Luke 43719 Posted November 3 Posted November 3 Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
lessyen 1 Posted November 4 Author Posted November 4 I'm attaching the log after adding and manually identifying three movies for which metadata isn't displayed (though this isn't the case for all added movies—some are identified without any problems, but for others, the identification process takes quite a long time and not everything is displayed as it should be).. embyserver.txt
Neminem 2007 Posted November 4 Posted November 4 (edited) It looks like you movies are in the same folder /volume1/video/movies hd/Lolita (1997) FHD cz en.mkv /volume1/video/movies hd/>>lupinek/Naše divoká babička (2026) CZ dabing.mkv That might not work well. Your connection to TheMovieDB is also timeing out Connection to https://api.themoviedb.org/3/configuration/primary_translations?api_key=x_secret2_x timed out Read this. Movie Naming Edited November 4 by Neminem
Solution lessyen 1 Posted November 5 Author Solution Posted November 5 Yes, it was a MovieDB timeout. I changed the network settings - network requested protocol to IPv4 - everything works now!! Thank you so much 1
