Eigeplackter 117 Posted October 28 Posted October 28 Sorry, there's no appropriate subforum for problems with the website, but https://emby.media/community/ is being extremly slow since last week. Tonight HTML 500 Error was thrown and the forum wasn't available. Is there any work being done on the forum ? It's the only website I have problems with, all others load immediately. Im on Win11 with Google Chrome Version 156.0.8078.74 (Offizieller Build) (64-Bit)
Luke 43549 Posted October 28 Posted October 28 Hi, I think it's mostly performing normally but there have been some sporadic issues over the past several days that have been coming and going, that we are looking into. Thanks.
mwongjay 105 Posted October 28 Posted October 28 I use the fluid view and the performance has been slow for awhile from my recollection. You can improve performance by using a different view like table or grid. Otherwise you select a subset of forums
Eigeplackter 117 Posted October 28 Author Posted October 28 Im using table view, so that's not the issue. Will have to wait, maybe Luke and the team can find the issue. I guess you guys did the php-patch ?
mwongjay 105 Posted October 28 Posted October 28 6 minutes ago, Eigeplackter said: Im using table view, so that's not the issue. Will have to wait, maybe Luke and the team can find the issue. I guess you guys did the php-patch ? Open developer tools in your browser (F12) then click on the community/ request then click Timing. How long does the request take? For me, table view takes 358ms. For fluid with every forum it's 11.87s
pwhodges 2132 Posted October 28 Posted October 28 It's been like that since a major upgrade of the forum software some while ago. I mentioned it at the time, but no one seemed interested... Paul 1
Eigeplackter 117 Posted October 28 Author Posted October 28 (edited) Table 655,87 milliseconds Fluid 12,96 seconds Grid 646,98 milliseconds Edited October 28 by Eigeplackter
