Pad070 2 Posted October 25 Posted October 25 Hi, i'm not technically minded but have used Emby for a few years now and barring the odd login issue it's worked perfectly. Just recently it's running incredibly slow, the film libraries take an age to download and the main library of around 1400 films is impossible to scroll through, it's just blank once you get past the first 5-6 rows. I've tried changing cache size but it's not made any difference and I'm close to giving up on Emby and trying an alternative but wanted to see if I could maybe get some help here first? I've downloaded the log file but I read it's not safe to upload here? I'm using a Synology NAS too. thanks.
Luke 43549 Posted October 25 Posted October 25 Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
Luke 43549 Posted October 25 Posted October 25 hi, i would try removing the cover art plugin. then restart the server and see how things compare. Thanks.
RanmaCanada 601 Posted October 26 Posted October 26 What device are you using? I've noticed it's complete garbage on Apple TV, where as Android it's blazing fast.
