FFmpeg Pack update for HDR10+ metadata, audio track naming (streaming standards), and slow feature progress
4 minutes ago, ALLSTAR1986 said:
@LukeOkay, so do I need to update all the metadata? I did that for the series—it now says HDR10+—but the overlay from the CoverArt plugin still says HDR. Only after I reloaded the image does it show HDR10+, but that’s a bit tricky for me because I have a lot of custom covers. Is there a way to reload all the images without replacing them?
we haven't looked at the coverart plugin yet in regards to this. it may need an update but i'm not sure yet. but for all existing videos that are hdr10+, yes they'll need metadata refreshes.
ALLSTAR1986
 @LukeCould you check the CoverArt plugin and update it if necessary? Another thing I'm curious about: Can you make it so that Atmos is displayed alongside Dolby TrueHD? Right now, it only says “Dolby TrueHD,” and you can't tell right away whether the movie also has Atmos. This has already been brought up in other request threads; I think it should be easy to implement, just like with HDR10+.
atmos the last thing left we need to add detection for. Thanks.
ALLSTAR1986
@LukeIf you can integrate Atmos detection soon, I'll be happy again. Then the only remaining questions on my end would be about the exact bitrate as shown in MediaInfo and possibly 2fA for the admin. :)
And regarding the question above: After updating the metadata for movies, how can I display the HDR10+ overlay without having to reload each cover? I don't want to use the “Delete and Replace Cover” feature because, as I mentioned, I have custom covers.
I noticed: If you want to filter by video type, HDR10+ is missing; that needs to be added.
Edited by ALLSTAR1986
samuelqwe
Even if it is less common, don’t forget about DTS:X ;)
  • Thanks 1
Delete the enhanced images cache on the server.
