Trouble with DTS audio : Synology (Emby server) --> Nvidia Shield Pro (Emby client) --> Samsung TV (display)
PaTRCK99
Hi,
I have a large collection of films stored on my Synology DS920+.
Most of these films have DTS audio tracks and PGS subtitles.
I am unable to watch these films with both the audio AND the subtitles working.
Emby Server is installed on the Synology, and the Emby client is installed on an Nvidia Shield Pro.
If I force audio conversion on the server, the playback constantly freezes (likely because the subtitles are being burned into the video frames).
If I don't force conversion on the server, I get no sound through my Samsung smart TV which do not natively support the DTS format.
I have spent hours trying to configure the server, the client, and the Shield Pro—all without achieving the desired result.
Perhaps this issue has already been resolved by other owners of Samsung smart TVs.
I would really like to be able to use Emby for a long time to come.
Thanks very much in advance for your help.
Patrick
PaTRCK99
Some additional details regarding my setup :
- I have a large number of 4K HDR films.
- Both the Synology and the Shield are on a 1-gigabit wired network.
- The Shield is connected via HDMI to the Samsung Smart TV.
- The audio output from the Samsung Smart TV is routed via an optical cable to a stereo DAC (PCM) and then to my hi-fi system.
Shouldn't the Shield be able to handle DTS? Do you have audio passthrough (for DTS) activated on the shield?
PaTRCK99
Thank you for your answer.
I haven't found a way to get the Shield to convert DTS. And also, I don't find any passtrough on the shield.
It works with Plex (DTS audio and PGS subtitles), but I really want to switch to Emby!
Lessaj
The Shield supports PGS subtitles, they do not need to be burned in. Disable DTS in the Audio settings on the Shield. My LG TV also doesn't pass DTS to my soundbar so I had to disable it. The Shield will automatically convert it on output once disabled. I can get a screenshot later if you can't find the options.
FrostByte
Do you not have a soundbar with HDMI in and out then?  You should connect the Shield to the soundbar if you do and then you should be able to play all the audio codecs you need for your 4K movies without converting.
My setup
Synology HDMI> Shield HDMI> Soundbar eARC> Samsung TV
But ya, turn off DTS and TrueHD audio on the Shield and it will automatically convert them to PCM, or click on Auto and it should automatically detect which formats your TV supports.
Lessaj
That'll depend on the soundbar, mine doesn't support 4k passthrough but works fine with ARC from the TV.
  • Like 1
Lessaj
Android Settings -> Device Preferences -> Display & Sound -> Advances sound settings -> Available formats
If there are issues with Auto try setting to Manual and disable DTS and DTS HD
Edited by Lessaj
  • Like 1
FrostByte
True, that would be the way to go with that setup though if the OP doesn't have one and wants to get one.
PaTRCK99, if you do get one look for this in the specs.  I believe all the Samsung 5.1/7.1 soundbars support 4K passthrough.  A lot of the ones with lower channel support don't.  Which makes sense.
Video Feature
4K Video Pass
120 Hz
And you need at least 1 HDMI in, 1 out, and eARC.  If it has 2 HDMI input then you can plug in something like an Xbox also.
Connectivity
HDMI In
2
HDMI Out
1
HDMI ARC
Yes (eARC)
vs a lower end model that says
Video Feature
4K Video Pass
No
Lessaj
Ah right they're using SPDIF so no soundbar involved here, they have a separate HiFi system.
  • Like 1
FrostByte
Thanks, I missed that
PaTRCK99
I don’t have a soundbar.
My TV’s audio is routed to the stereo DAC of my "traditional" hi-fi system (a stereo amplifier and two speakers). The setup produces excellent sound—when there is any sound at all.
In the Shield’s settings, I’ve unchecked the DTS format to indicate that it isn’t supported by the TV; this should, in theory, force the Shield to transcode DTS into AC3 (PCM).
That’s how it works with Plex, for instance.
However, with Emby, there’s no sound—it’s as if the audio is simply "forgotten."
I’m aware that it’s possible to use an Emby add-on within Kodi; while that supports all audio formats, the user interface is too limited, making navigation a chore.
That is why I’m looking for a way to use Emby while maintaining support for all standard audio formats.
Thanks for your ideas!
FrostByte
Are you using the AndroidTV app (version 2.5.03 I believe is the latest), or the standard Android app?
If ATV: Are the DTS/TrueHD boxes below the ones you adjusted to force the server to transcode?  They should be checked on and in the Shield/Android settings they should be checked off.  That should tell the app to passthrough and then the Shield would convert them to PCM.
If that doesn't work, then have you tried the other Android app to see how it compares?
Edited by FrostByte
PaTRCK99
Hello,
Thank you all for your contributions.
I have finally found a solution for my setup. It’s not 100% satisfactory, but it works.
The main issue is that my Samsung smart TV does not recognize the DTS format (shame on Samsung!). Consequently, the DTS audio must be transcoded beforehand.
The Emby client cannot communicate with the Nvidia Shield to trigger DTS transcoding (unlike Plex, for example), so the transcoding has to be handled by the Synology NAS.
I have an Emby Premiere subscription, which allows for hardware-accelerated transcoding (using the GPU). This is where things don’t work as expected.
If the Synology transcodes the DTS audio for a 4K movie without subtitles, it works fine—the playback is smooth, and CPU usage stays below 30%.
However, if I enable subtitles, the video freezes every ten seconds, even though CPU usage is only at 40%.
The workaround is to limit the conversion resolution to 1080p; in this case, CPU usage drops back to 30%.
This is unfortunate, as I have a collection of 750 4K films, many of which feature DTS or DTS-HD audio—Emby effectively forces me to watch them in 1080p.
I’m curious why the Synology’s CPU isn’t being utilized to its full potential, which might otherwise resolve the issue.
If any Emby developer has an answer, I’d love to hear it.
In any case, thanks for everything!
Patrick
PaTRCK99
To clarify: the issue only occurs with subtitles in PGS format... which remain widely used in videos.
PaTRCK99
One further detail: in the user settings within Emby Server, I must force the conversion of both video and audio.
If I only force the audio conversion (which might seem sufficient, given that the issue only concerns DTS audio), the PGS subtitles are lost—as if they were being baked into the video frames during the conversion process.
Lessaj
This doesn't sound right, the Shield fully supports PGS subtitles and should be able to convert the audio format on output. I retested my DTS settings and didn't seem to need to disable it, looks like it's being converted to Dolby Digital on the fly based on what my TV was indicating, but I know your setup is different and that's not a true comparison. Please provide some logs.
PaTRCK99
Thanks for your message, Lessaj.
The issue is that Samsung Smart TVs do not recognize the DTS format, so it must be converted before being sent to the TV.
If "passthrough" is disabled in Emby, the Shield fails to identify that it needs to perform this conversion—oddly enough, even when the Shield’s advanced audio settings specify that DTS is not supported for output.
Consequently, the DTS must be transcoded by the Synology NAS.
This is where the NAS becomes overwhelmed—specifically when playing 4K content with DTS (or DTS-HD) audio and PGS subtitles.
The Synology integrates PGS subtitles into the video.
The NAS’s GPU cannot properly process PGS subtitles, forcing the CPU to handle the task as well, which leads to total system saturation.
This is why the only viable solution I’ve found is to convert the video to 1080p in Emby Server.
After, the Shield’s upscaling capabilities and the Smart TV’s own processor help minimize any loss in quality.
