skept 13 Posted October 21 Posted October 21 Radio Meta enhances internet radio playback in Emby by displaying live song information instead of leaving the station’s .strm filename in the Now Playing display. Features include: Live song information: Displays the current song title and artist as radio metadata becomes available. Station artwork: Supports station logos and artwork alongside radio playback. Station-specific settings: Configure metadata behavior for individual stations. Adjustable metadata delay: Fine-tune when updated metadata appears to help manage transitions between songs and stations. Flexible metadata modes: Customize how radio metadata is handled, including options designed for different playback scenarios. Emby integration: Designed to work with radio stations already set up as .strm files in your Emby music library. The goal is to make internet radio feel more like a properly integrated music experience in Emby, with clearer Now Playing information and better station presentation. Radio Meta is actively being developed, with a focus on reliable metadata updates and consistent artwork across playback devices. Use Tapermonkey and load the RadioMeta-Userscript in the browser on your local machine you can see what the script does. Use the WebLoader to replace the file in emby that controls the player displays and you can get the output on every browser player. (installer is for windows) RadioMeta.dll RadioMeta-Userscript.zip WebLoader.zip 2
skept 13 Posted October 22 Author Posted October 22 (edited) updated userscript Radio Meta-Userscript.zipt Edited October 22 by skept I can not spell
GrimEvil 110 Posted October 23 Posted October 23 We need an easier way to set this up for the average user. I can get the plugin to create stations, I then add them to a music library, and the items play, In the plugin you see the metadata, but of course nothing shows in emby. I added the nowplayingbar.js to my emby install, but no update or metadata shown in the player for me. I may not have installed everything required of course
skept 13 Posted October 24 Author Posted October 24 You may need to restart emby. I do every time I update for testing. and refresh your browser Ctrl-F5, once its working it stays working. In the bottom of the plugin there is a diagnostic that may give a hint. if you PM me that output I can take a look. I am desperately trying to get some type of injection to the now playing and players without changing files or requiring the userscript.
skept 13 Posted October 24 Author Posted October 24 The current build of the webloader. WebLoader.zip
skept 13 Posted October 24 Author Posted October 24 you might have to completely close your browser and open again after restarting the emby server.
skept 13 Posted October 24 Author Posted October 24 are you using edge? I use firefox and safari and thought nothing of it. I am trying to play in edge and its throwing an error
skept 13 Posted October 24 Author Posted October 24 Ok, I think I found the problem. Edge (and maybe others) was blocking the script from loading. I relocated it in the dll and it appears to work better now. The updated webloader and dll are included. Make sure you shut down emby before applying the dll and webloader. these are very low level so emby needs to start with the files installed as far as my experience. I also hit ctrl F5 just in case. A point, if you open Radio Meta and its blank, make sure your address bar looks like /web/index.html#!/configurationpage?name=RadioMetaDashboard. I changed the page name from v16 and sometimes it remembers the old. people who have not install this yet will not have this problem. RadioMeta.dll and WebLoader 1.3.74 R7.zip
GrimEvil 110 Posted October 24 Posted October 24 That's working now and I can see the metadata in my browser for my radio station now. Of course it would be ideal if this worked in the android/apple apps as well
skept 13 Posted October 24 Author Posted October 24 So about carplay, if you use your browser (Safari/Chrome) you can display in carplay without issues. I needed to add a 2 second delay to keep that strm artwork. and you need to keep your phone unlocked, it will update for about a minute after lock but after that no. I am hoping for app support too, If I could find a working code injection point I might be closer. I have not had success with the api.
GrimEvil 110 Posted October 24 Posted October 24 Maybe inject it into the now playing or audio info using the api some how so it over rides the default?
skept 13 Posted October 24 Author Posted October 24 I was able to get the song title reliably with the api but nothing else and that was only in the dashboard now playing. it never showed up in the browsers without either the userscript or the modified file. I am asking for more information that may not be listed, we shall see.
skept 13 Posted October 25 Author Posted October 25 Fixed an issue with big player having to refresh when mini player already contained the metadata. safari/firefox (and likely others) in IOS now updates the lockscreen after extended lock and thereby Carplay (Now Playing) while the screen is locked. I have not tested on android but the expected behavior is the same. make sure to clean browser cache to load the current plugin RadioMeta-v1.3.95.zip contains the RadioMeta.dll and WebLoader
GrimEvil 110 Posted October 26 Posted October 26 When you use a dark theme in emby some of the buttons do not work correctly May need a fix for that
skept 13 Posted October 27 Author Posted October 27 Confirmed, I will look into the theme fix. Thank you.
skept 13 Posted October 30 Author Posted October 30 Sorry for the delay. I was beta testing some improvements and could not merge. The theme issues should be resolved. In this release we gain adaptive metadata searches to hopefully reduce the time it takes to get the data and hopefully use less resources. I have made changes to the interpretation of the metadata. Some stations do funky things, or the name doesn't translate well. i am trying to get that all automatic so the manual meta controls will not be required but... Also, in this release we gain better stability of the lockscreen on your phones, for me the only time I lost the metadata from the lock screen/Carplay is when I lost a good connection to the server due to data issues. I am happy with this fix. We also added a proxy option. For some time I was unable to play https://das-edge93-live365 stations and some others due to some issue with how emby uses ffmpeg so what this does is play the link directly in ffmpeg , Downside is it opens two ffmpeg for a second, but it will drop the first and only have one. I have used this on some channels to improve playability, but it is not required for most. This option adds another file to the .strm folder to make this work. I will be releasing the code for this project on GitHub for those who care Radio-Meta This plugin also contains a diagnostic at the bottom to troubleshoot issues. Eventually that will be removed when bugs are swatted. I still have not resolved the display issue on the players or dashboard. The code has not changed in the WebLoader so you likely will not need to apply this if you already did on the last release. If I crack this issue, we will not need to use the WebLoader at all. As always make sure you restart emby after you install and hit ctrl-F5 on the browsers. on your phone you may want to clean the cache just to be sure. I found an issue with Tampermonkey/Violentmonkey/Firemonkey and I assume the others. While the userscript works in my situation I saw banding on emby when I selected to play. this was happing when I clicked on a .strm to play and did not seem to cause any further issues but it was annoying. This happens even If I removed the script and just left the extension in Firefox. lots of little changes to improve functionality but I forget right now and they were mostly all backend. RadioMeta-v1.3.126.zip
skept 13 Posted November 3 Author Posted November 3 I found the issue with the internal display output. I was chasing my tail so I stripped out the front end and started again. The plugin is all you need now. Do not use the WebLoader. restore with the WebLoader or manually replace the original file. after replacing the dll make sure you restart emby and restart your browsers, recommend crtl-F5 and cleaning cache on phones. now we need to get app support...RadioMeta.dll Radio Meta The code if anybody cares.
skept 13 Posted 30 minutes ago Author Posted 30 minutes ago Stability improvements Web Streams now supported if your m3u or stream has icy data restart emby and crtl-f5 your browser RadioMeta.dll 1
