FrostByte 5685 Posted October 20 Posted October 20 Issue: With a spotlight at top when you arrow down to continue watching it doesn't display the current selected items backdrop but still shows the backdrop of the spotlight movie when background images is turned on. However, if you remove the spotlight then the background image is the currently selected item from continue watching. Expected behavior: Like with the Android app when background images is turned on it displays the backdrop of the currently selected movie/episode from the next section below spotlight. 2.5.1 Samsung 2018 Q8FN Steps: Enable Background Images in Geneal Settings With a spotlight in the first section of the Home screen scroll down one section. Continue Watching in my case Backdrop doesn't change to the selected item and continues to show the spotlight image Disable Background images in settings Now the correct background is shown Picture below is from the Android app which you can see the All Creatures Great & Small background. In the Samsung app it would still show the Peaky Blinders backdrop from the spotlight when at the same place.
Luke 43719 Posted October 20 Posted October 20 Yea I think ultimately what it will do is scroll you down so that you don't even see the spotlight anymore. Then that wont' be an issue anymore. 1
