nicko84 72 Posted October 26, 2013 Posted October 26, 2013 I don't know if it is about server or mb-classic but is there a way to hide missing seasons and episodes for tvshows ? Thanks
gillmacca 17 Posted October 26, 2013 Posted October 26, 2013 If you haven't got a season/episode, Mb classic and the web client will not show them
nicko84 72 Posted October 26, 2013 Author Posted October 26, 2013 (edited) Thanks for your answer But i'm sorry, MB classic does exactly the contrary. Even i don't have the season or some episodes it displays all seasons and episodes missing with a red banner "Missing" on each items (each images of season or episode). The "virtual" seasons and episodes names appears in grey and not in white I think it can be modify but i don't know how. PS : I've installed the latest MB server (3.0.5046.28735) and MB classic (3.0.84.0 B10-25.1) dev releases. Edited October 26, 2013 by nicko84
gillmacca 17 Posted October 26, 2013 Posted October 26, 2013 That's a new feature on the dev build of the server. I'm only using beta's, so can't help there, sorry
Solution ebr 16354 Posted October 26, 2013 Solution Posted October 26, 2013 I strongly urge you to back off of dev releases if you are using the system for real. You are going to end up getting a lot of partial implementations and even more bugs.
nicko84 72 Posted October 27, 2013 Author Posted October 27, 2013 I'm using MB2 for several years now on my real library and i use MB3 on a test library for few weeks with dev releases to see what great job the dev team do. I'm waiting for the next stable release to migrate from MB2 to MB3 using Krakt not to loose watched/unwatched status. Best regards
