Bobby121418 17 Posted October 18 Posted October 18 Hi, Streaming 4K 60-90mbps files from my Synology DSM 7.3 from another country causes a lot of buffering the first time I hit play. But if I stop and start play again once or twice, the problem is resolved.borh networks have fast 200mbps+ connections. Research online shows that this is a TCP congestion issue. Has anyone had this issue? If so, is there a solution? Many thanks
Luke 43719 Posted October 18 Posted October 18 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Bobby121418 17 Posted October 18 Author Posted October 18 3 hours ago, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! Hi, Attaching latest log here. Please see from about 23 :00 hours on 18 October or 00:00 19 October (if local server time). I made two tries: 1. Bufferings where the stream does not recover 2. Stream starts and plays normally Many thanks embyserver.txt
Luke 43719 Posted November 4 Posted November 4 Hi, even though you have a theoretical 200mbps+ on both sides, you could also have ISP port throttling on either side. Have you looked into that ?
