JulsPlus 1 Posted October 8 Posted October 8 Good Day, I have a few m3u8 channels that I am streaming. I had been using NPM run/grab batch schedules to fetch the guide data to an xml. A little clunky and not always reliable. However, I recently discovered Emby has many different Guide Data Sources available. Wow, so neat and clean. I’ve replaced the NPM grab for almost all my m3u8 channels but am struggling to find 2, below. RAV (Real America’s Voice) OAN Plus The channels are freely available on Pluto and that is the NPM source I have been using (not reliable at all, 50/50). Is there a reference list for the Emby Guide Data Sources that I can use to quickly find the correct Emby Guide Data Source and Channel number? It would be super helpful. **** I imagine that might change all the time and would be super difficult to maintain. Still, a dump of the data periodically would be great. Or maybe there is a file sitting somewhere within the program on my PC. Who knows? Thank you in advance, As always, all help is greatly appreciated, Julie
Luke 43719 Posted October 8 Posted October 8 Hi, you may just need to find an xml data source for those and import their guide data that way.
JulsPlus 1 Posted October 8 Author Posted October 8 Yes, I've been using NPM grab to populate an xml. But its extremely unreliable and somewhat unstable. The Emby Guide Data Source seems much more stable, clean and preferred. There seems to be quite a few different sources with many, many channels. I'm sure they are in there some where. Just now sure of the easiest way to find the channels within the Emby Guide Data Source. 1
