Wonderstuf
I just bought a new Firestick and Emby doesn't connect to my server. It does connect via Silk.
Forgive the text below but I was running my troubleshooting via ChatGPT and ask it to summarise what we tested and the environment:
I’m having a problem connecting the Emby app on a new Amazon Fire TV Stick HD to my local Emby Server. I’ve done quite a bit of troubleshooting and it now appears that the Fire TV itself can reach the server, but the Emby app cannot.
One potentially important detail is that this is a 2026 Fire TV Stick HD, model AFTCL001, running Vega OS 1.1, rather than the older Android-based Fire OS. Amazon’s device specifications confirm AFTCL001 as a Vega OS device.
Setup
Server
  • Emby Server 4.10.1.0 on Windows
  • Server LAN address: 192.168.1.60
  • HTTP port: 8096
  • Windows network profile: Private
Fire TV
  • Fire TV Stick HD (2026)
  • Model: AFTCL001
  • Vega OS 1.1
  • LAN address when tested: 192.168.1.170
  • Gateway: 192.168.1.1
  • Same 192.168.1.x subnet as the Emby server
The Emby app reports:
“Unable to Reach Server. We’re unable to connect to the selected server right now. Please ensure it is running and try again.”
I have tried manually connecting to:
http://192.168.1.60:8096
with the same result.
Troubleshooting carried out
Initially the Fire TV was connected by Ethernet. I disconnected Ethernet and tested it using my normal home Wi-Fi as well.
The Emby app fails to connect on both Ethernet and Wi-Fi, so this does not appear to be specific to the wired/powerline connection.
I checked the network configuration. The server and Fire TV are on the same subnet and use the same gateway.
I changed the Windows network profile from Public to Private. Windows then prompted me to allow Emby through the firewall, which I allowed.
I also checked Windows Defender Firewall with Advanced Security. Emby has TCP and UDP inbound rules enabled, and I made sure the TCP rule applies to the Private profile.
The Emby Android app on my phone connects successfully over the same home network. The server log shows normal connections and playback from that device, so Emby Server is accepting LAN connections.
Fire TV browser test
I then opened Amazon Silk on the same Fire TV and entered:
This successfully reached the Emby web interface and presented the server login page.
The Emby Server log confirms these requests came from the Fire TV at 192.168.1.170. At 22:50 and 22:52 the server received authentication requests from the Fire TV running Silk. The requests reached Emby normally and returned a 401 because an incorrect password was entered during that particular test.
This therefore appears to establish that:
Fire TV → LAN → Windows PC → TCP 8096 → Emby Server is working.
No incoming request from the Emby app
This seems to be the most significant part.
At approximately 23:07 on 6 October, I attempted to connect again using the Emby app on the Fire TV and received “Unable to Reach Server”.
There is no corresponding incoming request from the Fire TV in the Emby Server log at that time.
This is noticeably different from the Silk browser test. When Silk on the same Fire TV accesses exactly the same 192.168.1.60:8096 address, its requests immediately appear in the server log.
So it appears that the failure occurs before the Emby app establishes a connection with Emby Server, rather than Emby Server receiving and rejecting the connection.
Obviously the server log can only establish that no incoming request reached the server. It cannot tell me whether the Fire TV app attempted an outgoing connection which then failed locally or somewhere before reaching the server.
Could Vega OS be significant?
Having investigated the device further, I discovered that AFTCL001 is one of Amazon’s newer Vega OS devices rather than an Android/Fire OS device.
I also found previous discussions here about Emby on Vega OS, including references to the existing Fire TV/Android app being provided on Vega devices through Amazon’s translation/cloud-stream technology while a Vega-specific Emby app is being developed.
Could this therefore be a Vega OS / translated-app local-network-access issue?
It would seem consistent with what I’m seeing: Silk running on the Fire TV can access the local Emby server, whereas the Emby app apparently cannot establish the connection at all.
Is there a Fire TV/Vega client-side log that would show the app’s attempted outgoing connection and why it is failing?
Remote access
For completeness, I also tested remote access from my phone with Wi-Fi disabled and the phone using 5G. Remote access currently fails as well.
I realise this may be a separate port-forwarding/remote-access issue, because the Fire TV and server are on the same LAN and the Fire TV can demonstrably reach the server through Silk at 192.168.1.60:8096.
Where I've got to
At this point I believe I've ruled out:
  • Emby Server not running
  • Incorrect LAN server address/port
  • The Fire TV being unable to reach the PC
  • General TCP 8096 connectivity between the Fire TV and server
  • Windows blocking all LAN access to Emby
  • An Ethernet/powerline-specific problem, as the app also fails over Wi-Fi
The key distinction is:
Silk browser on Fire TV → reaches Emby Server
Emby app on Fire TV → no request appears to reach Emby Server
I’ve attached the Emby Server log covering these tests. The failed Emby app connection attempt was at approximately 23:07 on 6 October.
Any suggestions for what to check next, particularly regarding Vega OS/local network access, or which client-side logs would be useful?"
Hope someone can help.
J
SamES
@Wonderstufcan you please confirm the app version number on the device?
newline
I'm having this exact same problem. Silk browser is able to reach my local Emby server, but the app can't connect.
Brand new FireTV 4K Select
Emby Version: 193  Last updated: Oct 6, 2026
Edited by newline
Wonderstuf
@SamESIt's 0.1.4 on the Firestick and 4.10.1.0 on the server.
SamES
Had either of you used the previous version 0.1.3? Did it connect correctly?
SamES
Can you also make sure the device has the latest firmware update?
SamES
OK, I've been able to reproduce this issue.  If possible, you should be able to connect to your server via https, otherwise a new version will be available soon. Thanks
  • Agree 1
Wonderstuf
Great stuff. Just to clarify, when you say a new version will be available soon, do you mean an update to the Emby app on the Fire TV/Vega OS, rather than an Emby Server update?
stevied421
@SamES I'm having the exact same issue on my Fire TV Stick 4K Select. Emby was working normally for me until October 6, then suddenly started showing “Unable to Reach Server.”
Every other device in my house can still connect to my Emby server. I also tested Silk on the same 4K Select and http://192.168.1.80:8096 works perfectly — I can log in and access my library. Only the Emby Vega app fails to connect.
I've already cleared the app data/cache, restarted the stick, forgotten/reconnected Wi-Fi, manually entered the server IP/port, tried Emby Connect, and removed the device from the Emby Server device list.
Since it was working before October 6 and then suddenly stopped, this seems to line up with the other reports here. Please let me know if you need any logs or testing from my 4K Select.
I'm also running Emby 0.1.4.
stevied421
And the https trick doesn’t work
Https does work but it needs to be a certificate that the device accepts.
stevied421
@Lukecan you walk me through how to do that or link me to a video that will show me I’ve never done it
stevied421
@SamESany update or progress just wondering
SamES
Just the Emby app on the FireStick. It's resolved in v0.1.5 which should come fairly quickly to the store
SamES
If you just want to do it to resolve this specific issue then it's probably just worth waiting for the fix.  The https option was just a work around in case you already had https configured.
stevied421
any update is the store just wondering
stevied421
Never mind my last post I’m an impatient person lol
It looks like Amazon released the update a couple hours ago.
newline
New version is working :)
thanks!
  • Thanks 2
