Home Screen Favorites Tab Remains Selected After Home Navigation
scottpro
Summary
When navigating from the Home screen to the Favorites screen and then returning to the Home screen using Home navigation, the Favorites tab remains selected.
Steps to Reproduce
1. Start on the Home screen.
2. Navigate to the Favorites screen.
3. Return to the Home screen using one of the Home navigation methods, such as:
  • Home icon  🏠
  • Home key
  • Remote Home button
Actual Result
The Home screen is displayed, but the Favorites tab remains selected.
Expected Result
Returning to the Home screen using Home navigation should restore the default Home tab selection rather than leaving the Favorites tab selected.
Additional Information
The issue appears to be related to the selected tab state not being reset when the Home screen is reopened through Home navigation.
Web App version: 26.0.33
Server Version: 4.10.1.0
TV Display mode: both modes are affected
Neminem
DO you have some screenshots of that.
Would like to see it, because I have not see it, I might be looking at the wrong place.
scottpro
It is very simple to reproduce the issue.
If using a mouse:
  1. Start from the Home screen.
  2. Click on the Favorites tab at the top/middle. The Favorites screen is displayed.  Do not click on any movies.
  3. Now press the Home key on the keyboard.
The Home screen now appears but the Favorites tab is still selected.
If using a keyboard:
  2. Use the direction arrows and highlight the Favorites tab.  The Favorites screen is displayed.  Do not use the direction keys while in the Favorites screen.
This is not a big issue, but just wanted to report it to the dev team.
Correction: The Home icon 🏠 is not present on the Favorites screen so only the keyboard Home key or Remote Home button are used in this case.
Lessaj
Essentially the focus is still on Favourites when you hit home on the keyboard because if you press Enter after it will go back to Favourites (since it's the focus) but you can see Home light up a little as it's the active section.
  • Disagree 1
scottpro
Correct, the Home text is brighter but the selection tab is still on the Favorites, and if you hit enter/space it will go to the Favorites screen.  I think the normal operation should be if you are on the Home screen than the Home tab is selected and if you are on the Favorites screen than the Favorites tab is selected.  Having the Favorites tab selected while on the Home screen seems like it's out of sync.
This is an edge case bug and not a big issue.
BTW, this bug also occurs with the local server web UI.
Edited by scottpro
It’s actually all one screen. One screen with two tabs
Is this in the web app?
scottpro
Yes, my original post states that.
What browser and browser version?
scottpro
Chrome: Version 154.0.8037.93 (Official Build) (64-bit)
  • Thanks 1
