quick bit of urgentish advice requested
ginjaninja
need to get my public ip..away from home...no-ip has lapsed..can i find my public ip by logging into connect service?
i have a user configured as connect user...and server is running
thanks
Nick
Edited by ginjaninja
Beardyname
Connect removes the need for a specific dns service :)
(But for reference if you check the server dashboard it will list your external IP)
ginjaninja
thanks..its a bust ..i can logon to web client...it shows my local server name...i click on it and nothing...perhaps my server has crashed..or i havent set up the connect user completely enough...will check when i get home..
Beardyname
If you can connect with the web-client in the box where it says : "Remote access" It lists your internal IP? Because i don't think that is possible :P
