Chapters - Android vs Android TV
I have been using the ATV on my Shield Pro for ages, and tried and stopped using the Android version due to how it operates the Chapters features.
With the ATV app, you can access Chapters via pushing the Up button after any other action to do with playback (apart from Sop obviously). That is, you can skip back or forward, then press up for Chapters, press down for info access to Subs etc then up for Chapters. On Android, you can only access Chapters via Up when nothing else has occurred and there is no on screen display, if you are in the Down button area, then you have to click down again, and another click to the right and wait for the chapters to load.
Another major pain point is that the Android version doesn't show the current playback time.
In the example screen shots below, you can clearly see you're at 33:04 on ATV.
On Android, you have no idea. You only know that you're in the bracket 30:00-  34:59. If you are trying to skip forward 10mins as I constantly do with UFC, I don't know if that is two or three chapters.
I could accidentality end up with playback into action I do not yet want to see.
One positive is that it does show the Chapters are in 5 min blocks, but I know that already as I chose it in the server settings.
Android TV:
https://i.imgur.com/3TmteKQ.png
Android:
https://i.imgur.com/VEmh4WC.png
Edited by KRULL
  • 1 month later...
More the frustration of the changes/differences to how Chapters work in Android vs Android TV version.
When clicking up to engage Chapters, it always starts of at Chapter 1 0:00. #hrs into a 4hr show, click up to skip forward two chapters, but you are starting at 0:00 so you have to hold it forward to scan until you get to the current chapter, which you don;t where that is as you can't see where you are in the playback timeline.
It is stupidly quicker to click skip forward 20 times (30 second skips) than what should be three button pushes, UP, then forward two chapters.
I have found that if pressing Up once more after pressing Up to engage Chapters, that it will move the the highlighted chapter from Chapter 1 0:00 to the current Chapter, but you have less than 0.5 seconds to then press down again onot the Chapter timeline or the entire Chapter timeline will lower and not be selectable.
Can someone please have a look at how poorly Chapters selection and usage has been implemented vs the Android TV version where it just works as it should..
As it stands I will need to use the Android TV version for watching anything where I know I will be frequently using Chapters.
Quote
Hi, what Emby app version are you referring to?
Quote
Stay tuned, I will add this.
Android App is 3.5.72
Android TV is 2.5.07g
When I first started this thread, the issue I point out in my second post did not exist.
Hi, can you please try the latest build and let me know how that compares for you?
Thanks !
Thanks, FYI, Play Store is still on 3.5.72, so I downloaded it directly onto Shield.
OSD improvement is great, now can see the time. However, it is more miss than hit with which chapter it starts out when selecting. All of these Chapter engagements are via pressing Up.
As you can see in the screen shots, only one of them opened Chapter at the actual time being viewed. I got this to occur twice, I thought it may have to do with the initial engagement of Chapters, but no, I could not duplicate when it would occur. I tried skipping then opening Chapters, using chapters to move forward then engage it again, I couldn't get a duplication of examples consistently to say, If you do X, you will get Y result.
All other times it was not in the correct time. Example - playback at 20:20, first Chapter shown is Chapter 11 at 1:31:46
Second example, viewing at 1:31:54, but it opened Chapter 1 0:00:00
  • Thanks 1
Hi Luke, I noticed the published update notes :
3.5.78
  • Decoding fixes for 32-bit devices
Core UI Changes from 26.0.46 to 26.0.47
  • Improve chapter focus selection
I have just installed that and ran a bunch of tests, every test resulted in the default Chapter highlighted being the "Watching" one, so accurate to the playback timeline.
Thanks for getting these updates in quickly, greatly appreciated.
I would love to see the remaining usability that in the Android TV version be implanted here too, but at least the major issue has been dealt with.
Those features were the ability to bring up Chapters at any point in using playback, ie, skipping forward or back, or any other reason to have the playback timeline up, and pressing Up engages Chapters. Currently pressing up only engages Chapters if there is OSD related on the screen.
  • Thanks 1
CBers
Have you tried the latest ATV beta release?
I am on the Beta program, I was on 2.5.07g 8 days ago, now on 2.5.09g
ATV works well, that is the entre point of the post, to have Android work as well as ATV given they want to depreciate ATV.
Edited by KRULL
CBers
Perhaps add it to this long 100+ thread as well, although if the ATV app is being deprecated, why has it has so many feature updates recently.
It is head and shoulders above the Univeral Android app and always has been, although I don't use either nowadays.
I agree, and I was quite pissy when they said they were stopping development of ATV, as I found stock Android version to be lacking in may areas.
I haven't been on the forums in ages, it was only because I thought I would give the Android version another look to see if it was now useable, that I came across this still annoying feature gap that was stopping me using it.
I did search for other threads this may have a home, but not in the Beta section.
It seems that this thread still means it's clear as mud as to what is going on -
For what it's worth, I do think the Android version ends up giving.a better quality image than the ATV version. It is quite decent improvement on HD Web DLs, and then I fed them both 100mbps 4K remuxes, and it was still noticeable.
CBers
Possibly because the Universal Android app has a new version of Exoplayer from 2026, whereas I believe the ATV app still uses a version from 2023.
Edited by CBers
Perhaps but I'd be surprised if that was the actual reason.  Much more likely due to settings or playback process.
What settings within the app could do that?
Playback for both is set to max bitrate
There are a myriad of possibilities.  We'd have to look at specific playback examples.  If you want to do that, you should open a new thread for it.
Thanks.
