Kyouma 60 Posted September 27 Posted September 27 (edited) I have added the latest Episode of One Piece (S01E1180), but Emby fails to get the Metadata from TVDB. The Episode is availabe on the Site. I have removed and readded the item, but still get the same result. Tried a metadata refresh with no luck. Added the TVDB ID manually and then did a metadata refresh and then got this Error message 2026-09-27 23:48:23.249 Error App: Error in TheTVDB *** Error Report *** Version: 4.10.0.40 Command line: C:\Users\emrek\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.26200 OS/Process: x64/x64 Framework: .NET 8.0.30 Runtime: C:/Users/emrek/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 16 Data path: C:\Users\emrek\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\emrek\AppData\Roaming\Emby-Server\system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Tvdb.TvdbEpisodeProvider.GetEpisodeData(EpisodeInfo searchInfo, Boolean fillExtendedInfo, IDirectoryService directoryService, CancellationToken cancellationToken) at Tvdb.TvdbEpisodeProvider.GetMetadata(RemoteMetadataFetchOptions`1 options, CancellationToken cancellationToken) at Emby.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, LibraryOptions libraryOptions, String logName, TIdType id, IRemoteMetadataProvider`2[] providers, MetadataRefreshOptions options, CancellationToken cancellationToken) Source: Tvdb TargetSite: Void MoveNext() I have attatched the log, it starts at 23:40. Any help would be appreciated. The TVDB-Link for the Episode: https://thetvdb.com/series/one-piece/episodes/11994171 embyserver-2.txt Edited September 27 by Kyouma Add TVDB-Link
Solution Luke 43549 Posted September 28 Solution Posted September 28 HI, please let me know if the tvdb plugin update 1.6.7 resolves this. Thanks. 1
Kyouma 60 Posted September 28 Author Posted September 28 6 hours ago, Luke said: HI, please let me know if the tvdb plugin update 1.6.7 resolves this. Thanks. Removed the Episode, Installed 1.6.7 and then readded the Episode. Works properly now, thank you. 1
