oldred 0 Posted December 6, 2014 Posted December 6, 2014 (edited) I have been using MB forever...I run it on 2 HTPC. The problem I have is with HTPC1. I cannot get to the wrench. I have tried everything.Even went as far to do a uninstall and reinstall. It all works fine except it goes right into my movies folder..never get to see the listing of the new additions. Any suggestions?? Edited December 6, 2014 by oldred
oldred 0 Posted December 6, 2014 Author Posted December 6, 2014 The issue I am having is with Classic but I use them all
Beardyname 199 Posted December 6, 2014 Posted December 6, 2014 ah Well I don't use classic, hopefully someone else will recognize what could be causing this!
ebr 16334 Posted December 6, 2014 Posted December 6, 2014 Sounds like maybe there is only one top level folder and you have the option to Auto enter single item folders turned on. Hitting the back key should take you back though.
oldred 0 Posted December 6, 2014 Author Posted December 6, 2014 Back key???? Tried back button an windows remote just takes me out of MB
ebr 16334 Posted December 6, 2014 Posted December 6, 2014 And what version of MBC and server do you have?
oldred 0 Posted December 6, 2014 Author Posted December 6, 2014 All Fixed ...Added another folder In server dashboard...then went to HTPC1 and new entries were there along with new folder ...found wrench and unchecked auto enter single Item folders... Done... thanks much
ebr 16334 Posted December 6, 2014 Posted December 6, 2014 You must be using the old "Classic" theme? Most of the others will allow you access to configuration below the home screen.
