yocker 2084 Posted September 23 Posted September 23 1 hour ago, sobeitjedi said: Ok, was just wondering how the post with the Blue Moon got the certificate to display? Have tried to install EmbyIcons Plugin, but it's not working. I'm running Emby 4.10.0.40 and tried to install EmbyIcons (twice - see below). Have restarted Emby after the plugin had installed, but it doesn't display under my installed plugins? Please give me a log of Emby trying to start with embyicons installed. I just fixed a problem in EmbyCredits that might be the same thing wrong here, i just want to be sure about the issue.
yocker 2084 Posted September 23 Author Posted September 23 3 minutes ago, sobeitjedi said: embyserver.txt 1.74 MB · 0 downloads As i thought.. I uploaded another version to the catalog v5.60.0.5. That should work correctly.
sobeitjedi 7 Posted September 23 Posted September 23 Installed, restarted Emby, but now Emby isn't coming back online, when I press run on my Synology NAS, after a few moments it says Manually Stopped ...
yocker 2084 Posted September 23 Author Posted September 23 (edited) 7 minutes ago, sobeitjedi said: Installed, restarted Emby, but now Emby isn't coming back online, when I press run on my Synology NAS, after a few moments it says Manually Stopped ... That's strange. Will look into it. Possible for you to grab a log ? Edited September 23 by yocker
yocker 2084 Posted September 23 Author Posted September 23 4 minutes ago, ebr said: Hi. I split this out to its own topic. Thanks. Sorry about that and thanks.
yocker 2084 Posted September 23 Author Posted September 23 @sobeitjediI just rechecked the log and i missed this before. I found this in the log "-noskia". EmbyIcons uses Skia for the drawing on the icons and without it will not work. I never thought about adding a check for that, which is embarrassing, so the plugin will just fail with the "-noskia". I'm very sorry about that!! Going to add a check for future version of EmbyIcons so this won't happen again!
sobeitjedi 7 Posted September 24 Posted September 24 13 hours ago, yocker said: That's strange. Will look into it. Possible for you to grab a log ? Sorry to ask something so basic, but if I can't load Emby, how do I get a log?
yocker 2084 Posted September 24 Author Posted September 24 39 minutes ago, sobeitjedi said: Sorry to ask something so basic, but if I can't load Emby, how do I get a log? It should create a log even though it shuts down. It doesn't matter though, i found out what was wrong in the last log. Again sorry about it.
sobeitjedi 7 Posted September 24 Posted September 24 (edited) Any idea how I get Emby back online? Is there an EmbyIcons dll file to delete? Will that work to restore access? Edited September 24 by sobeitjedi
yocker 2084 Posted September 24 Author Posted September 24 2 hours ago, sobeitjedi said: Any idea how I get Emby back online? Is there an EmbyIcons dll file to delete? Will that work to restore access? Yes, in the plugins folder there is a embyicons.dll file, just delete that
yocker 2084 Posted September 24 Author Posted September 24 2 minutes ago, sobeitjedi said: Ok, thanks, will give it a try If you can't do it via the file manager then you will have to ssh in and delete /var/packages/EmbyServer/var/plugins/embyicons.dll "sudo rm /var/packages/EmbyServer/var/plugins/embyicons.dll" in terminal. If you need more help then please ask. 1
sobeitjedi 7 Posted September 24 Posted September 24 Removed the dll from /volume1/@appdata/EmbyServer/plugins (different location to what you suggested, but I assume that's fine) and now I can load Emby again - thank you Question is, should I try EmbyIcons again? Has whatever the issue was, been corrected?
yocker 2084 Posted September 24 Author Posted September 24 23 minutes ago, sobeitjedi said: Removed the dll from /volume1/@appdata/EmbyServer/plugins (different location to what you suggested, but I assume that's fine) and now I can load Emby again - thank you Question is, should I try EmbyIcons again? Has whatever the issue was, been corrected? Sorry about that, i just gave you the location that was shown in the logs. Happy to hear it's working again though! Emby for your system sadly lacks SkiaSharp that the plugin uses to drawn on the posters. So it won't work. I'm working on and off on making it compatible but it's slow going and i don't have a Synology to test with. One day the support will be there. For now a guard against the plugin trying to execute on a system like yours has been added.
sobeitjedi 7 Posted September 24 Posted September 24 No problem, appreciate your help anyway, thank you 1
