marriedman 110 Posted 34 minutes ago Posted 34 minutes ago I made this program to scratch a personal itch. I do not use Emby metadata scrapers. I manage that through tinymediamanager and curate what gets written to the NFO file and save the actor image in the .actors folder. Even though I am relatively thorough and retentive about what gets saved to file, I sometimes miss things. I started this project as a simple script for personal use , then it morphed into a python project, and it finally just snow-balled into a full fledged application. AgentNFO is a free and open-source tool that will help you manage actors, directors, writers, producers... any person based XML tag in an NFO. You can manage duplicate actors, incorrect profile images, set default actor images, and clean/homogenize Studio names. AgentNFO can be deployed as a Docker image or native installation. After you get it up and running, you can use it as a PWA (progressive web app). IMPORTANT - AgentNFO is distributed as a Linux container and is designed to run anywhere compatible Linux containers are supported. Development and production testing are currently performed on Linux. Windows and macOS hosts using Docker Desktop may also work, but are not currently tested or officially supported. AgentNFO on Codeberg I made this open-source because I hope someone far smarter than I will take this and run with it. I have a a few ideas kicking around that I might implement, but I have to tell you... I am sick of developing and it was only a few months!
