casminkey 20 Posted September 15 Posted September 15 Curious if I'm doing something wrong or I have misunderstood how to sort channels. I have them in the order I'd like from the Dashboard, Live TV, Channels. But when I go to the guide, with sort order selected to Default Channel Order, the one NFL Redzone channel isn't at the top like it is in the Channels. Any idea how to get this sorted?
ebr 17102 Posted September 15 Posted September 15 Hi. Can you discern what order they are showing in? Like maybe last played? What happens if you change the sort to something else and then back to default?
Solution richt 113 Posted September 16 Solution Posted September 16 The Guide page doesn't update until after a guide refresh.
richt 113 Posted September 16 Posted September 16 9 hours ago, Luke said: HI, is this the web app? I'm assuming the OP needs to answer this question as well. In my case, yes, this is in the web app.
casminkey 20 Posted September 16 Author Posted September 16 9 hours ago, Luke said: HI, is this the web app? In Chrome browser, yes.
casminkey 20 Posted September 16 Author Posted September 16 11 hours ago, richt said: The Guide page doesn't update until after a guide refresh. I'm fairly certain this was after a guide refresh but now it's good. I noticed it was sorted correctly last night on my Google TV.
casminkey 20 Posted September 16 Author Posted September 16 16 hours ago, ebr said: Hi. Can you discern what order they are showing in? Like maybe last played? What happens if you change the sort to something else and then back to default? Yes and sorting by channel number shows them in the correct order but then when going back to default channel order they were not in the right order. It eventually corrected itself. 1
