denz 516 Posted September 15 Posted September 15 I really enjoying using android tv and with WMC theme looks great just wished the recording indicators on the tv guide are larger they are currently tiny.
denz 516 Posted September 17 Author Posted September 17 It is is tiny it should be at least 2 times bigger so it looks nicer here you can’t distinguish is it a single or series recording
ebr 17088 Posted September 17 Posted September 17 Okay, you are using the old non-compact view of the guide but it seems they are still quite noticable. Any larger won't work well on the default compact view.
ebr 17088 Posted September 22 Posted September 22 I have made these a bit bigger in the latest beta. 1
