zebo51 22 Posted December 5, 2014 Posted December 5, 2014 (edited) I have this movie http://www.themoviedb.org/movie/13377-how-the-grinch-stole-christmas but it is actually pulling down the metadata for http://www.themoviedb.org/movie/240662-the-making-of-dr-seuss-how-the-grinch-stole-christmas My current folder format is: Dr. Seuss' How the Grinch Stole Christmas! (1966) I also tried How the Grinch Stole Christmas (1966) How the Grinch Stole Christmas! (1966) How the Grinch Stole Christmas! 1966 Any ideas on how to get it to pull down the right info? Thanks Edited December 5, 2014 by zebo51
Happy2Play 9814 Posted December 5, 2014 Posted December 5, 2014 Have you used the Identify in metadata manager and entered the tmdb id (13377)? 2
yardameus 221 Posted December 5, 2014 Posted December 5, 2014 I would think How the Grinch Stole Christmas! (1966) should've worked.
zebo51 22 Posted December 5, 2014 Author Posted December 5, 2014 Have you used the Identify in metadata manager and entered the tmdb id (13377)? ah, didn't know that little trick. I also put in the right IMDB ID and now it seems to pulled the right data and pictures. Thanks
Solution ebr 16354 Posted December 6, 2014 Solution Posted December 6, 2014 Have you used the Identify in metadata manager and entered the tmdb id (13377)? This is the correct answer but you don't have to go looking up the correct ID - that's what this form is for. Just blank out the IDs that are there and enter the name and then select the proper one from the list that appears. 2
zebo51 22 Posted December 6, 2014 Author Posted December 6, 2014 Great, will do although this is I think the only one in over a year that hasn't read right. At least that I have come across. Is there a way I should mark this thread as answered or anything? Thanks
Angelblue05 4132 Posted December 6, 2014 Posted December 6, 2014 Just marked as solved the post that answered your question.
zebo51 22 Posted December 6, 2014 Author Posted December 6, 2014 I guess that option is not available in the general discussion form. Now that it is in the windows server support I see Best Answer buttons. Thanks again. 1
