Emby Multi Connections
Uncle_Frank
I have a few mag boxes each with it's own subscription you only can use on one mac address at a time and I remember years ago testing out how it was said you can watch using emby the same channel on multiple devices at the same time. Back when I tried it before it never worked but now I can confirm I had it working on 3 devices at the same time it actually does work now 🙂 but it needs to be the same channel on each device or it stops working and only streams on one device but still this is pretty cool. I was thinking it's too bad you never had favorites locked down as a tag instead of the way you have it now or we could really take advantage of the tags feature on here.
