msaritama
Hola, desde cualquier navegador o app de celular con Emby Server local se podia enviar por cast mi musica a mi jbl authenics 500 por UPnP. Ahora que migre Emby Server a un servidor en AWS  no funciona el cast, se queda cargando y luego sale error. He hecho de todo y no he podido hacerlo funcionar, es necesario adquirir Emby Premiere para que funcione el cast? en Jellyfin no tiene este problema y se conecta a Cast sin problemas pero Emby me gusta mucho mas. Gracias
image.png.1519f51bc94b8a5bbf096ff3a6b4a004.pngimage.thumb.png.ad8782f097929d28e0605dabf0306197.png
Hi, that's strange. Are you still having an issue with this? Can you give it another try?
msaritama
Yes, I'm still having the issue. I ran some more specific tests and here's what I found:
- Casting DOES work perfectly from this same Emby server on AWS to a Google TV 4K (Direct Play, FLAC 994kbps, no errors).
- Casting does NOT work to my JBL Authentics 500 (a speaker with Chromecast built-in) — it just sits on "Connecting..." and never actually connects. In the Emby logs (with debug logging enabled), there's no sign of any connection attempt from the JBL at all, as if it never even reaches out to the server.
- I confirmed the JBL can receive casts from custom apps just fine: using Jellyfin, on the same AWS server, same domain, same network, casting to the JBL works without any issue.
This makes me think it's not a problem with my network, my SSL certificate, or the JBL device itself (which we now know can receive casts from third-party apps), but something specific to how the "Emby for Chromecast" receiver app communicates with audio-only Cast devices (no screen), like the JBL, even though it works perfectly with Chromecasts that do have a screen.
Is it possible the Emby receiver app has a known issue with audio-only Cast devices? Thanks again for the help.
  • 2 months later...
Hi @msaritamacan you please give it another try? Thanks !
