DannyDee316 4 Posted September 11 Posted September 11 Hi Guys, I tried to set emby up on an Philips 85PUS8500 LED TV. On several other Samsung, Sony and Philips TVs or mobile devices it works fine. I tried using the IP adress as usual, but I also tried emby connect and the Synology Server name. But it says that no connection to the server is possible. Is there anything special with this TV? I am using Synology DS1821+ with emby 4.9.5.0 Can anybody help? Best regards, Dan
DannyDee316 4 Posted September 13 Author Posted September 13 (edited) Here are photos of the app in the appstore and from the welcome screen. No further infos available. Can you work with it? Btw no other Emby App like "Emby for Android TV" is available on this TV. Only this one. Edited September 13 by DannyDee316
Luke 43719 Posted September 15 Posted September 15 OK, are you trying to connect to your own Emby Server, or someone else's server?
DannyDee316 4 Posted September 16 Author Posted September 16 198.168.178.157 with the pre-configured port 8096 and I also tried emby connect without any effect
Luke 43719 Posted September 18 Posted September 18 HI, for TitanOS, currently you need to setup SSL for this to work. please see this topic for more info; Â
DannyDee316 4 Posted September 22 Author Posted September 22 (edited) Thank you it worked. But unfortunately it only worked once with the app. In a second run the app does not connect properly anymore. I can gladly share a photo later on. My workaround is using emby with the https address over the internet browser now. That works fine, but I have to control it with a mouse cursor via tv remote. Edited September 22 by DannyDee316
Luke 43719 Posted September 22 Posted September 22 48 minutes ago, DannyDee316 said: Thank you it worked. But unfortunately it only worked once with the app. In a second run the app does not connect properly anymore. I can gladly share a photo later on. My workaround is using emby with the https address over the internet browser now. That works fine, but I have to control it with a mouse cursor via tv remote. Hi, what exactly happens the second time?
DannyDee316 4 Posted September 23 Author Posted September 23 After loading the app and connecting to the server the screen attached pops up. No matter what I am choosing from there it directly returns to the same screen. Also there is no possibility to uninstall the app or reenter anything else either.
Luke 43719 Posted September 24 Posted September 24 On 9/23/2026 at 5:19 AM, DannyDee316 said: After loading the app and connecting to the server the screen attached pops up. No matter what I am choosing from there it directly returns to the same screen. Also there is no possibility to uninstall the app or reenter anything else either. That looks like the exit menu, right? Are you pressing back?
DannyDee316 4 Posted September 25 Author Posted September 25 Yes lools like it, but it appears automatically without me doing anything. No matter what I select it comes back in a loop.
Luke 43719 Posted September 25 Posted September 25 2 hours ago, DannyDee316 said: Yes lools like it, but it appears automatically without me doing anything. No matter what I select it comes back in a loop. OK we'll take a look at it. Thanks.
