djmbrfc 1 Posted September 9 Posted September 9 Hi, I am new to emby so not an expert and I would appreciate a bit of help with this issue I have..... There are 2 apps on the firestick for emby the "Emby for Fire TV" and "Emby" "Emby" refuses to play DTS audio. "Emby for Fire TV" plays DTS perfectly. How do I fix the "Emby" app to play DTS? I am using the Firestick 4K 2025 edition Thanks in advance.
djmbrfc 1 Posted September 9 Author Posted September 9 Thanks for the response.. Yes I think so ...... Looks a bit too involved for me so I will stick with the "Emby for Fire TV" Will try "Emby" now and again in the hope it gets fixed!
djmbrfc 1 Posted September 9 Author Posted September 9 Hi, "Emby" refuses to play DTS audio but plays the movie OK "Emby for Fire TV" plays DTS perfectly, it also didn't play DTS at first but I found it has the option to prevent DTS-HD passthrough. When I unchecked this all played great. While "Emby" does no have this passthrough option available.
Luke 43680 Posted September 9 Posted September 9 Hi there, what exactly do you mean by refuses? Are you saying it tells you that it won't play the track?
djmbrfc 1 Posted September 9 Author Posted September 9 It directly plays the video OK and stats for nerds states the audio is being directly played but no sound coming out of the speakers.
Luke 43680 Posted September 9 Posted September 9 As the Emby TV app actually playing the DTS or is it down mixing it?
djmbrfc 1 Posted September 9 Author Posted September 9 (edited) It's being directly played no transcoding or down mixing. The movie and sound also plays OK when using the Samsung TV app but it transcodes the audio automatically, Edited September 9 by djmbrfc
djmbrfc 1 Posted September 9 Author Posted September 9 Force Audio Transcoding in Emby: Open the Emby app on your Fire Stick, go to Settings > Playback, and look for audio output options. Ensure that DTS-HD/TrueHD options are unchecked or set your audio output to a format your TV/Receiver natively supports (like Dolby Digital). This forces the Emby server to convert the DTS-HD track into a compatible format (like AAC or Dolby Digital) on the fly. You can do the above on the "Emby" app but not on the "Emby for Fire TV app.
ebr 17088 Posted September 9 Posted September 9 1 hour ago, djmbrfc said: I found it has the option to prevent DTS-HD passthrough. When I unchecked this all played great 1 hour ago, djmbrfc said: It's being directly played no transcoding or down mixing Are you positive? I think the TV app is most likely remuxing to DD (AC3) since you de-selected the passthru. The problem is that some systems that support DTS can accept a DTS-HD stream and just extract the core from it and work fine. The Fire Stick, however, may not be able to do that. You could also look in the settings for the Stick itself and see if there is an advanced audio option that will allow you to select/deselect exactly which formats to support.
djmbrfc 1 Posted September 9 Author Posted September 9 Just loaded VLC on the firestick and the video and DTS audio play OK. So at the moment I am experimenting using the "Emby" app to browse my media then using VLC as an external player to play it.
ebr 17088 Posted September 9 Posted September 9 3 minutes ago, djmbrfc said: Just loaded VLC on the firestick and the video and DTS audio play OK That's because VLC is based on ffmpeg so it is mixing it down in software. Did you look for the settings I mentioned on your Fire Stick?
djmbrfc 1 Posted September 9 Author Posted September 9 No audio settings on the fire stick help with this issue
ebr 17088 Posted September 9 Posted September 9 12 minutes ago, djmbrfc said: No audio settings on the fire stick help with this issue Was there an "Advanced" setting that let you choose the formats? I know Android has that.
djmbrfc 1 Posted September 10 Author Posted September 10 (edited) Yes but none make any difference, Not a problem with the fire stick. The fault must be with "Emby" as "Emby for Fire TV" works ok. "Emby" sees the DTS audio and does nothing. "Emby for Fire TV" sees the DTS audio and automatically converts to a suitable format. Edited September 10 by djmbrfc
ebr 17088 Posted September 10 Posted September 10 6 hours ago, djmbrfc said: Yes but none make any difference You specifically turned OFF DTS-HD?
djmbrfc 1 Posted September 10 Author Posted September 10 (edited) You cannot turn off DTS-HD It's the "Emby" app that's the problem! VLC woks, Plex works and "Emby for Fire TV" works. Edited September 10 by djmbrfc
djmbrfc 1 Posted September 10 Author Posted September 10 Also Emby Samsung TV app works and Emby for Windows works
ebr 17088 Posted September 10 Posted September 10 2 hours ago, djmbrfc said: You cannot turn off DTS-HD What options did it give you in the advanced audio? Can you show a screenshot?
ebr 17088 Posted September 10 Posted September 10 Here's what it looks like on the Shield but the Fire may not have this level of control:
djmbrfc 1 Posted September 10 Author Posted September 10 Looks nothing like that .... I am not altering the firestick setting as ever other app works fine including "Emby for Fire TV" so the problem is with the other "Emby" app. So I will continue to use "Emby for Fire TV" or Plex or VLC when watching movies with a DTS audio track when using my Fire Stick. Thanks for your efforts anyway.
Luke 43680 Posted September 16 Posted September 16 On 9/10/2026 at 4:27 PM, djmbrfc said: Looks nothing like that .... What does it look like?
djmbrfc 1 Posted September 18 Author Posted September 18 I don't know how but this issue has been resolved. The "Emby" Firestick app now recognises DTS audio and automatically transcodes it. I have not changed any settings but the issue I reported has seemingly gone away by it's self! 1
