sa2000 890 Posted September 10 Posted September 10 58 minutes ago, sa2000 said: I have opened an issue with Gracenote for "Radio 1's New Music Show with Jack Saunders" to ask for the airings to be at episode level in the schedule instead of being just the show/series name and identifier. I have setup as a test a recording series schedule for this series - and i will see the results after this evening. Also will try it after that with the option to check the library and not record if already in the library. The next airing after today is the 14th There may have been some changes in the emby server beta - you could try out the latest beta (currently Emby Server 4.10.0.40) to see if the outcomes are different I presume you have a record series shcedule setup for "Radio 1's New Music Show with Jack Saunders" and not recording manually
Landoman 33 Posted September 10 Author Posted September 10 (edited) Wrong response. Edited September 10 by Landoman
Landoman 33 Posted September 10 Author Posted September 10 On 09/09/2026 at 16:42, ebr said: If you are actually talking about "Windows Media Center" how are you getting any guide data at all for that now? I thought that was cut off years ago. In any case, I believe that, you think it is "working fine" because it is not trying to determine if you already have any particular showing of any particular item already and is just happily recording duplicates. We are using the guide data to avoid recording duplicates and, according to the guide data, this would be a duplicate. Please do not contribute to this issue. Others are dealing with it.
Landoman 33 Posted September 10 Author Posted September 10 (edited) 8 hours ago, sa2000 said: I have setup as a test a recording series schedule for this series - and i will see the results after this evening. Also will try it after that with the option to check the library and not record if already in the library. The next airing after today is the 14th There may have been some changes in the emby server beta - you could try out the latest beta (currently Emby Server 4.10.0.40) to see if the outcomes are different I presume you have a record series shcedule setup for "Radio 1's New Music Show with Jack Saunders" and not recording manually Great, thank you for troubleshooting this. Yes, I have a recording series setup for Matt and Mollie, the Jack Saunders recording was just a test. If i were testing I would use the Matt and Mollie as that seems to have the most issues. Just checked and there theres an update to emby, Version 4.9.5.0. I will continue to record and monitor. This is odd, radio on is show as radio one but is actually kiss fm. I will delete the tuner and readd it. I will also check the guide listing to make sure they are correct. I have added multiple emby guide sources. The guide is now correct. I will test over the test few days with a few different shows to see if its working properly. Edited September 10 by Landoman
sa2000 890 Posted September 11 Posted September 11 (edited) 14 hours ago, Landoman said: This is odd, radio on is show as radio one but is actually kiss fm. I will delete the tuner and readd it. I will also check the guide listing to make sure they are correct. That was why I said do not use the national lineup but use the one for your post code - either Local Over The Air Broadcast or Freeview - then 700 would be BBC R1 and would auto match to the channel from the tuner during initial setup On the National lineup BBC R1 is 181 and channel with callsign KISSRDO is 700 - so please delete that lineup and use Freeview or the Local Over the air Broadcast The standard OTA lineups to use would show like these highlighted one in the green boxes - The Freeview one would show the relevant one for your post code 14 hours ago, Landoman said: Yes, I have a recording series setup for Matt and Mollie, the Jack Saunders recording was just a test. If i were testing I would use the Matt and Mollie as that seems to have the most issues. The initial response from Gracenote was positive and they are looking into getting the airings for Radio 1's New Music Show with Jack Saunders and Charlie and Jerry corrected. The bad news is that each show/series that has issues needs to be investigated and reported separately. I will look into Matt and Mollie next Edited September 11 by sa2000
Landoman 33 Posted September 11 Author Posted September 11 (edited) Using the national service may have been the issue however it was set to Over the Air Broadcast previously when the errors occured. I have deleted all of them and just added local ones. So it was an issue with Gracenote as well as the guide listing data. That's good news. I'm testing recordings with a few other radio channels. Once they have completed I will update. Edited September 11 by Landoman 1
Landoman 33 Posted September 11 Author Posted September 11 (edited) We have a problem: both emby guides set to OTA I did not stop and start the recording. However the episode may have had breaks in it due to news and it treating it as another program. Edited September 11 by Landoman
sa2000 890 Posted September 11 Posted September 11 30 minutes ago, Landoman said: both emby guides set to OTA I do not understand why you need both guides - it is an either ... or ... They should be identical With regards to investigating recordings, for each case I would need to know the channel number and channel name on the guide/tuner. I can guess but i do not want to do that. And if you are getting multiple recording files where the guide does not show them as separate entries, then i would need server debug logs covering the time from start of first recording for the day to the end of one that is duplicate Concentrate on one of these and i will investigate
Landoman 33 Posted September 11 Author Posted September 11 (edited) I have deleted the second emby source. It is now set to Local Over the Air Broadcast (which is what is was set to at first) currently recording. Server log will be sent via DM. I will record Radio 1 Dance Party with Danny Howard and let it finish normally and see what happens to the filename. Tuner Channel 700 Channel Number. Edited September 11 by Landoman
Landoman 33 Posted September 11 Author Posted September 11 (edited) It failed to correct the name but did record the entire show. Edited September 11 by Landoman
sa2000 890 Posted September 14 Posted September 14 FYI Gracenote have corrected airings details in the BBC R1 schedule for these shows Radio 1's New Music Show with Jack Saunders Going Home with Vick, Katie and Jamie on Radio 1 The Official Chart: First Look on Radio 1 with Lauren Layfield Refresh the guide and see what you get in the schedule for the next airings for these 3 shows. Note that there is 24 hour caching in Emby Server for guidedata before a change would be picked in a guide refresh
sa2000 890 Posted September 14 Posted September 14 On 11/09/2026 at 20:45, Landoman said: It failed to correct the name but did record the entire show. Thanks for the log - yes it just created the one file 2026-09-11 18:23:02.051 Info LiveTV: Copying recording stream to file Y:\Emby Recordings\Radio 1's Dance Party with Danny Howard\Radio 1's Dance Party with Danny Howard 2021-09-10.ts The filename issue is similar to what you see for the others - this happens when the schedule from gracenote just gives the show information. The setting for the recording for check whether the episode is in the library already will determine if further airings are recorded or not. If that setting is not enabled, then they should get recorded for subsequent airings and would all have the same base filename. I expect them to be playable as if there were different versions
Landoman 33 Posted September 14 Author Posted September 14 (edited) Is there are alternative to gracenote to stop this from happening? Shouldnt the OTA data override gracenote? Edit: I'm trying an XML EPG downloader to see if I can get the data from that. Edited September 14 by Landoman
sa2000 890 Posted September 14 Posted September 14 For Matt and Mollie - wait for the Gracenote changes 1 hour ago, Landoman said: Is there are alternative to gracenote to stop this from happening? Shouldnt the OTA data override gracenote? At the moment, I am in discussion with Gracenote on this. Also raising it with the Emby development team to see if there is any changes we can make. Meanwhile, If you can find an xmltv source for the schedules for the radio channels that is precise for the aired episode, then look into that and map these channels to the xmltv source. Removing the check on the library for existing episodes for just these radio channel recordings would allow you to keep multiple days recordings and view by date added
Landoman 33 Posted September 14 Author Posted September 14 I used EPG and downloaded the data. First test appears successful as it got the show name and the show time https://github.com/iptv-org/epg
sa2000 890 Posted September 14 Posted September 14 1 hour ago, Landoman said: used EPG and downloaded the data. First test appears successful as it got the show name and the show time https://github.com/iptv-org/epg great ! Thanks for the feedback
Landoman 33 Posted September 19 Author Posted September 19 (edited) Unfortunately still some issues. The guide isn't downloading some channels. Where does WMC get its data as its all correct? Is it OTA? If so why is the OTA not decoding properly for one program and not the other? Is the emby listings option gracenote? or an OTA provider? Edited September 19 by Landoman
ebr 17102 Posted September 19 Posted September 19 6 hours ago, Landoman said: Where does WMC get its data as its all correct? This would have to be something you setup as Microsoft discontinued guide data six years ago. Most likely, you setup some sort of system that is ultimately getting the data from Schedules Direct which, ironically, gets their data from the exact same place we do - Gracenote. That would point to probably a lineup or channel-mapping difference or, less likely but possibly, some "extra sauce" SD is adding.
sa2000 890 Posted September 21 Posted September 21 (edited) On 19/09/2026 at 09:12, Landoman said: Unfortunately still some issues. The guide isn't downloading some channels If there are some missing OTA channels in the guide, please let me know the emby guide name and identifier and the post code used to select it and what channels are missing. On 19/09/2026 at 09:12, Landoman said: If so why is the OTA not decoding properly for one program and not the other? If you are referring to the original air dates issue reported originally for programs like: Radio 1's New Music Show with Jack Saunders Radio 1's Dance Party with Danny Howard The Official Chart on Radio 1 with Jack Saunders Going Home with Vick, Katie and Jamie on Radio 1 Matt and Mollie Gracenote have now adjusted the guide for BBC Radio 1 (channel 700) - to give episode identifiers instead of the generic series/show identifiers for all of the following: 1Xtra's R&B Show with Chuckie BBC Introducing Rock on Radio 1 Danny Howard's Club Mix Going Home with Vick, Katie and Jamie on Radio 1 Matt and Mollie Pete Tong Radio 1 Breakfast with Greg James Radio 1 Dance Drum & Bass Mix Radio 1's Chill Mix Radio 1's Classic Essential Mix Radio 1's Dance Party with Danny Howard Radio 1's Drum & Bass Show Radio 1's Future Artists with Sian Eleri Radio 1's Future Dance with Sarah Story Radio 1's New Music Show with Jack Saunders Radio 1's Pop Anthems Radio 1's Power Down Playlist with Sian Eleri Radio 1's Rap Show Radio 1's Rave-Up with Arielle Free Radio 1's Rock Show with Daniel P Carter Radio 1's Soundsystem Party Radio 1's Workout Anthems The Official Chart on Radio 1 with Jack Saunders On 19/09/2026 at 09:12, Landoman said: Is the emby listings option gracenote? or an OTA provider? The Emby Guide data is provided to us by Gracenote. Edited September 21 by sa2000
Landoman 33 Posted September 22 Author Posted September 22 So manual recording is ok. I am using OTA local as the guide data. It did not trigger recording the series. I noticed and had to do it manually. The data is correct but I have no idea why it is stopping and recording again. Show started 30 min ago. Recording series was selected but it was just greyed out.
sa2000 890 Posted September 22 Posted September 22 16 minutes ago, Landoman said: So manual recording is ok. I am using OTA local as the guide data. It did not trigger recording the series. I noticed and had to do it manually. The data is correct but I have no idea why it is stopping and recording again. Show started 30 min ago. Can you tell me what these 2 settings are in the Series Recording Settings for this
sa2000 890 Posted September 22 Posted September 22 Thank You - can you please download the embyserver.txt log and attach it - the current log should cover the time
sa2000 890 Posted September 22 Posted September 22 (edited) Thanks for the log - please supply the full embyserver log file and not an extract from it Also please enable debug logging on the server - go server settings dashboard and select logs in the left side bar under Emby Server heading and then click on the Logs Settings tab and set "Enable debug logging" to Yes. That will help with tomorrow's recording and looking at the guide refresh requested below And please do a guide refresh - Server Settings Dashboard / Live TV / Click on Refresh Guide Data When it completes, go the Home screen, select Live TV and then select the Series tab and open up the Matt and Mollie Series recording page and get me the screenshots for the whole screen - i want to see how many epiosdes show and if the red indicator for to-be-recorded is showing - screenshots equivalent to this from my server and then send me the embyserver.txt log file after this - this should have debug logging now and show if timers are set for th airings Edited September 22 by sa2000
