Orionas21 8 Posted September 7 Posted September 7 Hi All, I have changed couple of weeks ago from Emby for AndroidTV to EMby for Android in my Sony Bravia in order to test the interface and the functionality of it. I was a little bit disapointed so i decided to switch back and install 2.1.55 rel but then nothing was working. I was unable to play any movie from my internal LAN to Sony Bravia. I rollback to 2.1.48g without success and then back to 2.1.23g to finally be able to play the content. embyserver-63924257771.txt embyserver-63924336000.txt embyserver-63924173908.txt
Luke 43680 Posted September 8 Posted September 8 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
Orionas21 8 Posted September 8 Author Posted September 8 Hi Luke, The EMBY for Android was working ok without any issue. In the uploaded files you may notice that it is ok 3.5.55 release. Yet the Android TV version has simpler interface in regards of settings and more robust user management especially for kids profiles. The internal storage is unfortunately limited on this TV so I can not maintain both apps.
Luke 43680 Posted September 8 Posted September 8 Quote Yet the Android TV version has simpler interface in regards of settings HI, what makes you think it's simpler?
Luke 43680 Posted September 8 Posted September 8 Quote more robust user management especially for kids profiles. Hi, what makes you think it's any different in this regard?
Orionas21 8 Posted September 9 Author Posted September 9 (edited) Look at those differences. To go to settings I push one button while in Android 2 and it opens also server settings... The menu in kids movies is simple and neat. Yet have you identify the issue? My TV auto update again the app and again I'm not able to play anything. Edited September 9 by Orionas21
Luke 43680 Posted September 9 Posted September 9 The second screenshot is a left flyout menu to allow you to quickly reach any of the top level sections. A lot of apps do that nowadays. We could add an option to allow you to hide all of the server settings.
Luke 43680 Posted September 9 Posted September 9 but they also wouldn't be there if your kids weren't using an administrator account. you'd be seeing far less in that situation.
Orionas21 8 Posted September 9 Author Posted September 9 Also the subtitle menu is different. It is huge and covers almost all the screen. I want to change the position of the subs and the menu actually hides them. One more is the zoom. You have more options in ATv than auto,fill, cover... Many more interface things that personally I dislike. In regards of the accounts I don't want to create multiple. I want to have as less as I can. I monitor my server real time so in case I see any abnormal behavior I stop the movie and pop-up a text. This is not the reason that i opened this issue, to debate about the interfaces. Do you have any update on the reported issue? Do you need additional logs? I know that the team wants to promote the Android client but some off us still prefer the simple things in ATv and generally in life!! Thank you for your effort!! 1
ebr 17088 Posted September 9 Posted September 9 Just one more slight de-rail of the topic... May not be something you want to consider but Roku devices are known for their simple interfaces and our Roku app mirrors that. It works much like the Android TV app but even simpler in some regards (there are no context menus for instance). So, that could be something you want to consider for your kids. Just a suggestion. 1
Luke 43680 Posted September 10 Posted September 10 Hi, the subtitle appearance menu is docked to the right side though, right? Quote We could add an option to allow you to hide all of the server settings. And this has been added for the next update to the app.
Orionas21 8 Posted September 10 Author Posted September 10 (edited) 59 minutes ago, Luke said: Hi, the subtitle appearance menu is docked to the right side though, right? And this has been added for the next update to the app. The 1st menu with the SUBS yes it is in the right side but it is huge. The second menu for the Subs Appearance is in the center and also huge. It covers almost all the screen. Edited September 10 by Orionas21
Luke 43680 Posted September 12 Posted September 12 On 9/10/2026 at 4:13 AM, Orionas21 said: The 1st menu with the SUBS yes it is in the right side but it is huge. The second menu for the Subs Appearance is in the center and also huge. It covers almost all the screen. OK but that screenshot appears to be on a phone, right? On the TV it would be in the lower right similar to the other menus down there.
Orionas21 8 Posted September 12 Author Posted September 12 Yes that one is from a phone which is also bad and inconvenient. The new one is from Tv.
Luke 43680 Posted September 17 Posted September 17 On 9/12/2026 at 3:51 AM, Orionas21 said: Yes that one is from a phone which is also bad and inconvenient. The new one is from Tv. With the next app update it will be docked to the right like so: At least on TV. On small mobile screens it will still be the same. 1
Orionas21 8 Posted October 5 Author Posted October 5 Any update why EMBY for Android TV is not working in Sony Bravia after 2.1.48g?
ebr 17088 Posted October 5 Posted October 5 6 hours ago, Orionas21 said: Any update why EMBY for Android TV is not working in Sony Bravia after 2.1.48g? Have you tried the latest beta? If it still has the issue, can you please reproduce it and then follow the instructions to send a log from the app?
Orionas21 8 Posted October 5 Author Posted October 5 No i haven't. Where i can find it? In the 1st post i have upload 3 different logs from 3 different version. Did you check them?
ebr 17088 Posted October 5 Posted October 5 47 minutes ago, Orionas21 said: No i haven't. Where i can find it? 47 minutes ago, Orionas21 said: In the 1st post i have upload 3 different logs from 3 different version. Did you check them? Those are server logs. I'd like you to please play that item for a few seconds and then follow the instructions to send a log from the app? 1
Orionas21 8 Posted October 16 Author Posted October 16 OK I have updated the app to 2.5.03g When I press the play button i see black screen and nothing else. Waited 1 minute but nothing happened. Pressed the back button nothing happened. Eventually home entered again the app and then sent the debug logs. Orionas21 is the name of the user. Pressure and Specter was used as test movies.
ebr 17088 Posted October 16 Posted October 16 Thanks for the log. This is an odd one that I've never seen before and is unique to this TV apparently. We will figure out a way to address it in a future update. In the meantime, you can use the standard app. Thanks.
Orionas21 8 Posted October 17 Author Posted October 17 7 hours ago, ebr said: Thanks for the log. This is an odd one that I've never seen before and is unique to this TV apparently. We will figure out a way to address it in a future update. In the meantime, you can use the standard app. Thanks. Thank you for the info!! The new glass menu and theme looks awesome!!! 1
Solution ebr 17088 Posted November 2 Solution Posted November 2 Please test this with the latest beta version 2.5.0.5. Thanks.
Orionas21 8 Posted November 9 Author Posted November 9 I'm pleased to inform you that it is working. I have tested it with beta and the official release. Thank you for your support!! 1
