BiberM 3 Posted September 3 Posted September 3 Dear community, with some mkv files I see a strange behavior when watching mkv videos on my Samsung TV from 2025 (S95F I think). No matter what language is selected during playback the audio track remains a certain one. Sometimes it is the last (e.g. commented audio track) sometimes the first (then most of the times english). I copied the discs to my NAS using makemkv always copying the whole movie with all subtitles and audio tracks. I also tried changing the default track using MKVToolNix. User preferences are set to german and even ignore the default track. Both settings changed seperately with no effect. Server version is 4.9.5.0 (most recent stable) TV App version: 2.3.6 (most recent store version in germany) Is that a known issue? I could not find anything in the forum but maybe I used the wrong search terms. Could that be solved with the most up to date TV App version (2.4.8.)? Thanks in advance! Michael
Luke 43720 Posted September 3 Posted September 3 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
BiberM 3 Posted September 3 Author Posted September 3 Thanks for the quick reply and yes, I forgot that. There are 2 remux logs on the server. I first started playback on my PC using firefox (~19:24 in the logs). At 2026-09-03 19:25:16.506 is the first entry where I tried it on the Samsung TV. I was playing "Der Herr der Ringe - Die Gefährten". I've had this issue with a different movie some time ago but had no time digging into this. Am I missing some information? Best regards Michael ffmpeg-remux-77de9a6a-5721-4f7a-abcf-0e8c8c463086_1.txt ffmpeg-remux-31820edb-0c33-4616-a17c-52fc79da121c_1.txt embyserver.txt
Luke 43720 Posted September 4 Posted September 4 what track played? What track did you expect to play?
BiberM 3 Posted September 5 Author Posted September 5 Played was an english audio track. According to the ffmpeg logs this must be track 1 or 2. Also according to those logs track 5 has been marked as default and additionally it is the first german track, which is the user setting of the emby user trying the playback.
BiberM 3 Posted September 5 Author Posted September 5 (edited) I tried another movie which I had problems with. I removed all duplicate audio tracks comparing the language. E.g. English and german had 2 tracks each (DTS-HD Master and DTS). I removed the DTS tracks leaving eng and ger with DTS-HD Master and all other languages with AC-3. This resulted in playing the audio track with the highest number which in this case was turkish. Playback startet around 12:00:00. Thiss time only the embyserver.txt log is available. I attached it here. embyserver.txt Edited September 5 by BiberM added screenshot and correct audio codec for other languages
Luke 43720 Posted September 5 Posted September 5 How have you configured your Emby user audio settings? That’s what matters more than what track is marked as default in the file.
BiberM 3 Posted September 6 Author Posted September 6 For translation ger --> eng: preferred language: german play independent from the default track remember selected tracks The selected track on samsung TV UI was german DTS-HD Master.
Luke 43720 Posted September 6 Posted September 6 It probably remembered a selected track. You could try unchecking that option if you'd rather just have it always play the track marked as default.
BiberM 3 Posted September 7 Author Posted September 7 I was able to try this out today: I disabled both options. Still no change in the behavior. 1
BiberM 3 Posted September 12 Author Posted September 12 I just upgraded the samsung TV app version to 2.4.9 an tried playing Wolkig mit Aussicht auf Fleischbällchen again. Same error as before. During playback I switched languages (German --> Portugese --> English). Every time turkish kept being played. Log is attached. embyserver.txt
Luke 43720 Posted September 13 Posted September 13 Can you show me a screenshot of your user audio options?
Solution Luke 43720 Posted September 13 Solution Posted September 13 Never mind. The problem is you restricted all of the user transcoding permissions. Did you make sure to read the help text underneath those options?
BiberM 3 Posted September 13 Author Posted September 13 Hi, what help text do you mean? The one in grey underneat the "remember chosen track"? When disabling those options after your comment of Sept 6th I also used the link to clear all remembered chosen tracks. So this should then be eliminated and the next time the default track or forced german track should be chosen. But it isn't. Additionally I never chose turkish to be played. So there should never be something like that to be remembered. Or did you mean something else?
Luke 43720 Posted September 14 Posted September 14 @BiberMplease let us know if this resolves your issue. Thanks.
BiberM 3 Posted September 14 Author Posted September 14 That screenshot helped a lot! Thanks! And yes it works now. Many thanks for your time and patience. I was searching at app preferences --> <user> preferences --> playback. You pointed me to server settings --> users --> <user> --> playback, which is not the same. 1 1
