cv5404 4 Posted September 2 Posted September 2 Over the last few days I’ve noticed my posters (and some thumbnails on the continue playing) on my main page disappearing but only on my Roku TVs. iPhone, computer are fine no issues. I tried to reboot server, tv, computer etc then my category images (movies tv etc) disappeared as well. I’ve researched a little on past threads and stuff and it seems like I should maybe erase my cache folder on my computer. I just don’t want to go erasing things and rebuilding until I know it’s absolutely necessary. Attached is a few photos and my log. embyserver.txt
Luke 43542 Posted September 2 Posted September 2 Hi, can you show screenshots of the same screen in the web app? Thanks.
cv5404 4 Posted September 2 Author Posted September 2 4 minutes ago, Luke said: Hi, can you show screenshots of the same screen in the web app? Thanks. From my iPhone via web. I also took those of my daughters account but these are from mine. Nonetheless same shows you can see they’re showing fine in the web display vs the Roku
Solution Luke 43542 Posted September 2 Solution Posted September 2 OK I suppose you could try deleting C:\Users\redwi\AppData\Roaming\Emby-Server\programdata\cache\images and see if that helps. I would restart the Roku app after doing that.
cv5404 4 Posted September 2 Author Posted September 2 24 minutes ago, Luke said: OK I suppose you could try deleting C:\Users\redwi\AppData\Roaming\Emby-Server\programdata\cache\images and see if that helps. I would restart the Roku app after doing that. I will attempt it tomorrow and report back, Thanks Luke 1
speechles 2130 Posted September 2 Posted September 2 @ebrIs the PR#1809 (the maincard image fix) in the store version yet or is it just presently in the Beta and testing? This issue is likely fixed by #1809.
cv5404 4 Posted September 2 Author Posted September 2 I just deleted the specified file Luke said to I'm rebooting the server and my tv and will report back later. It'll need to repropagate right?
Luke 43542 Posted September 2 Posted September 2 1 minute ago, cv5404 said: I just deleted the specified file Luke said to I'm rebooting the server and my tv and will report back later. It'll need to repropagate right? it will happen automatically. in the short term you may notice slower server performance as it builds back up, just like if you installed the server fresh.
cv5404 4 Posted September 2 Author Posted September 2 5 minutes ago, Luke said: it will happen automatically. in the short term you may notice slower server performance as it builds back up, just like if you installed the server fresh. Looks to be cleared up! Thank you guys so much for your help as always. 1
