Theskid
Since this has been removed I can't play any guides with ac3/eac3/DTS or any surround on my TV on most android TV devices now since it was removed tried the new setting it doesn't work please re add the Audi output/downmix to stereo option back in playback settings
Edited by Theskid
Missed information
Hi there, what exactly makes you think it's been removed? Where exactly are you looking for it?
Are you using an optical audio connection or something similar that is not providing HDMI side-data?  If so, be sure you are configuring your audio settings in Android appropriately.
Alternatively, you can try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares?
Thanks.
  • 1 month later...
NailClipper
Hi.
I have the same issue. I have to do playback correction 3 times for every single surround sound movie/series so the audio got downmixed to stereo.
Why the option got removed? Please ass the downmix option back so we can use Emby on our TV again.
The Emby for normal Android is laggy, heavy, and is not optimized for TV usage. Even launching it took a few seconds and add a few seconds more for the splash screen to finished.
My only option is to wait for you guys to add the downmix option again.
Why?  What happens if you don't use playback correction?
chrono4548
If you don't do playback correction 3 times, you aren't able to convert the 5.1 audio to stereo for a 2.1 soundbar.
chrono4548
downgraded to 2.1.16 verison of emby. I was able to downmix to stereo.
It is connected via HDMI?  Or is it an old optical connection?
