Thigerlite 2 Posted August 30 Posted August 30 (edited) Hi all, I have set up Virtual TV plugin with about 30 channels and would like to show these channels in "Guide" view by default for all users on the home screen (similar to Pluto TV). I am specifically referring to the "On Now" section of the home page. Is that possible? Edited August 30 by Thigerlite
Thigerlite 2 Posted August 31 Author Posted August 31 Hi Luke, Thanks for responding quickly. Yes, the default shows the "On Now" as a group of posters indicating what is playing on each channel. Is there a way of replacing this with the full guide for those channels?
Solution Luke 43675 Posted August 31 Solution Posted August 31 There isn't a way to put the entire guide on the home screen if that's what you're asking for.
Thigerlite 2 Posted August 31 Author Posted August 31 1 minute ago, Luke said: There isn't a way to put the entire guide on the home screen if that's what you're asking for. Thanks, I was asking that. Reasonably new to Emby and still getting used to the interface and the way it works.
Luke 43675 Posted August 31 Posted August 31 OK yea that's a little more complicated because the guide has to have it's own embedded scrolling. So putting it onto a screen that also scrolls vertically would make it awkward to use. For instance you would try to scroll the screen and the guide would end up scrolling, or vice versa.
Thigerlite 2 Posted August 31 Author Posted August 31 Totally understand. Thanks for the detailed explanation. 1
