yocker 2078 Posted August 30 Posted August 30 As topic says, paused transcoded streams keep transcoding forever. Is this on purpose? I thought it was only supposed to transcode up to a certain point ahead.
Neminem 1984 Posted August 30 Posted August 30 Here is how to report a problem  Is transcoding throttle still turned on? Or is it still going after the stream is closed.  1
yocker 2078 Posted August 30 Author Posted August 30 24 minutes ago, Neminem said: Here is how to report a problem  Is transcoding throttle still turned on? Or is it still going after the stream is closed.  Didn't post logs because it's not really a problem but more of a question to how it's supposed to work.  Throttle is on, never thought about it before now so haven't tried without. The stream never gets closed, it's only paused by the user.. For hours... 1
Luke 43549 Posted August 30 Posted August 30 It’s normal, but the throttle feature will allow it to slow down. 1
yocker 2078 Posted August 30 Author Posted August 30 2 hours ago, Luke said: It’s normal, but the throttle feature will allow it to slow down. Thank you. 1
Q-Droid 1055 Posted August 30 Posted August 30 That sounds like the last couple of pages in this thread. At least back then it appeared to be media specific and I'm surprised Luke says it's normal. Â
Luke 43549 Posted August 30 Posted August 30 Sorry, for some reason I ignored the forever part. In most cases it should stop the transcode within 60 seconds, however, whether or not this occurs depends on what other activity is happening.
yocker 2078 Posted August 30 Author Posted August 30 1 hour ago, Luke said: Sorry, for some reason I ignored the forever part. In most cases it should stop the transcode within 60 seconds, however, whether or not this occurs depends on what other activity is happening. It just keeps transcoding forever though at a throttled speed when people pause their video or just quits the app.
Luke 43549 Posted August 30 Posted August 30 Universally that is not true, although it may happen in some situations. 1
