ALLSTAR1986 20 Posted August 30 Posted August 30 Hi everyone, I'm having an issue with automatic HDR activation in Emby for Windows (version 2.3.17.2.0) on an RTX 5080 connected to a 4K HDR TV. Setup & Working Features: GPU: Nvidia GeForce RTX 5080 (10-bit RGB Full) OS: Windows 11 Emby Version: 2.3.17.2.0 Working fine: 24p refresh rate switching and multi-channel audio passthrough work without issues. Issue Details: No Native HDR Trigger: Even with Enable Automatic HDR Mode Activation checked, playing HDR content does not trigger HDR on the TV (output remains in SDR/UHD). Display Control Status: Under Display Control, it statically shows HDR: on. On my previous PC, this showed disabled by default and toggled to enabled only during HDR playback to send the native signal. Rendering Engines Tested: Both Hardware Decoding (DX11 Video Acceleration / RTX 5080) and Software Decoding output in SDR (internal tonemapping occurs instead of sending native HDR10 metadata). Minor UI Bug: The UI defaulted to English on clean install and had to be manually changed under General -> Display Language. I have attached the log file below. Is this a known bug in build 2.3.17.2.0, or is there a specific driver/swapchain setting needed for the RTX 50 series? Thanks for your help! EmbyClient.txt
Solution softworkz 5734 Posted August 30 Solution Posted August 30 Please look at Windows Settings > System > Display > Graphics (IIRC, or 'Advanced Display') There's a setting like "Manage Color for all Apps" or similar. It puts the whole desktop into a kind of HDR mode and tone-maps colors back-and-forth for all apps. For the Emby Windows app, this looks like HDR is already enabled and there's nothing to switch to for enabling HDR. Please try to disable this setting and retry - you should get the same behavior like you've seen before.
ALLSTAR1986 20 Posted August 30 Author Posted August 30 Thanks, that was the problem. It must be a new Windows feature I hadn't seen it before but as always, this feature ends up making the workflow worse. I've now disabled it directly in the registry. 1
softworkz 5734 Posted August 30 Posted August 30 I'm glad to hear that it's working for you again. We'll have to find a way to detect this situation and warn about it in the app accordingly. Thanks a lot for the feedback, 1
